Fifth Wheel Hitch issue - How to correct?
humblerb
Long story, but I'll try to keep it as short as I can.
3 years ago, bought a B&M Patriot slider for my RAM 2500.
Had the dealer install rails. My first experience, so I didn't know any better. Dealer had trouble getting the base to fit in the rails. After an hour of working on it, they finally got it in.
Got home and discovered they installed the base backward.
I removed the pins, turned it around and went to reinstall it.
Took me about an hour of working with it to finally get the base in to the slots.
I could get any 3 tabs in, but the 4th took a lot of working around with a 75 pound hitch to get it in.
Recently bought a new RAM 3500 with pucks.
I bought a Reese adapter to use the pucks with the same hitch.
Now the four tabs slip in, but when I go to put the pins in, I can get the two toward the tailgate with no problem.
I can get either one of the two near the cab in, but the other does not go straight in - similar to the rail issue before.
If I use a hammer, I can beat the pins in. But, with the new truck, I am trying to make this process better going forward.
Measuring the pin holes on the base center-to-center, the holes are right at 28-7/8". They should be 29".
If I were to ream out the hole on one side (1/8") or both holes (1/16" each side) it should allow the pins to slide in.
This is half inch steel and is very tough.
Anyone have any thoughts on how to accomplish the ream?
I'm fairly handy, but I do not have any tools that would accomplish this.
Thanks for any help.
28 REPLIES 28
Cummins12V98
laknox wrote:
Instead of band-aiding this, since you have the pucks, why not sell the current Patriot and replace it with a Patriot OEM? Either used or new. Most B&W hitches in good condition sell for 50%, or more, of MSRP.
Lyle
Not sure if this is the same person but selling the existing and buying the puck slider was mentioned.
B&W's are easy to sell.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
laknox
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
Cummins12V98
Durb wrote:
I would call B&W and tell them your story. It sounds like your hitch was manufactured wrong from the outset. They may send you a new base.
100% agree to contact B&W. They will take care of you if there is a defect.
Let us know what they say.
cummins2014
MN Ben wrote:
Instead of reaming out the hole, I would suggest...
Remove the head from the rails. Loosen up the bed rails. Don't remove the nuts from the bolts, just loosen them enough where they may adjust when you put the head and pins back in.
Once you loosened up the nuts and blots, place the head back onto the rails. Now put all 4 pins into their holes. All 4 pins should be able to slip into their position easier. If they don't, tap on the rail that needs adjustment until the pins go in correctly.
After you get the pins to go in and out to your liking, leave the head on with the pins in place and tighten down the rails. Be careful not to over tighten the bolts to stress them. There is probably a torque setting you should use. I suggest contacting the company for this torque setting. If not available, reference a torque guide for the size and grade of bolt you are using.
Test the pins so see if they work better. Repeat if necessary.
I used this method and installing and removing my hitch head from the rails was so much easier and less stressful.
Good Luck, and let us know if this worked for you.
Ben
No amount of loosening those bolts will fix that's 28-7/8" , that's fixed , needs to be 29" I believe you are thinking front to back . But that doesn't apply here anyway ,he's on the puck system .
I have installed a couple sets of bed rails ,they need to be pretty accurate for sure ,or you have problems . Those frame adapters are not subject to that , unless they were built out of square . They fit the four pucks on the truck .
cummins2014
humblerb wrote:
Update:
Well, since I am retired and have lots of time on my hands - I found a coarse round file in my tool box. Used a little (or a lot) of elbow grease and manually reamed slightly. Repeated a few times. I was a little surprised at the ability of the round file, but it worked rather well.
Pins now go in with less hassle. The last one takes a little manipulation for now.
I'd rather have a little tight than a little loose.
As I install and remove the hitch in the future, I may decide to ream a little more.
Curious did you ream the adapter or the tabs, I believe I would ream the adapter , less metal thickness to deal with ,and no compromising those tabs , the adapter frame holes has plenty of steel there that it wouldn't weaken it at all . I know the tabs are pretty thick, but they are also not that wide .
Durb
cummins2014
humblerb wrote:
rhagfo wrote:
Well new truck with pucks, I would have the dealer check the install. I have a 2016 Ram 3500 with factory pucks and a Reese picture frame adapter. Mine drops in easily no issues at all. Your old issue with the rails was due to a sloppy installation. The fact that your hitch base drops easily into the frame slots, as they are made to the exact dimensions.
My issue is the same with rails and with pucks/adapter.
The tabs on the head nearest the cab are 28-7/8" apart instead of 29".
I just checked my adapter and its right on 29", they are slotted for the tabs ,but the hole is not ,so no there is no leeway for the pins. 1/8" would certainly prevent the pins from going in . Sounds like B&W did a poor job on welding on those tabs.
My Reese slider , and Andersen both fit that adapter well .
schlep1967
I would contact B&M. Either they made the hitch incorrectly or it got bent before or during installation the first time. They will probably ask for a lot of pictures so they can determine which one it is. Or possibly, they will know by the serial number that they made some out of spec units at that time. You might get a new hitch out of the time it takes to contact the company.
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
humblerb
Update:
humblerb
humblerb
Ben
Rails were in the old bed. Now have pucks with Reese adapter.
rhagfo
MN_Ben
Ben
2006 F350 Dually PSD
2008 Keystone Laredo 29RL 5th Wheel
2002 F250 7.3 PSD -SOLD
2004 Lance 1130 -SOLD
2005 Lance 981 -SOLD
2000 Lance 1010-SOLD
199? Texan 650 -SOLD
Ford FX4 Ranger -SOLD
BurbMan
You can use a carbide rotary file in your cordless drill to elongate the holes where you need to.
