โOct-15-2016 12:35 PM
โOct-24-2016 04:21 PM
S&B123 wrote:Kudos for taking the time to get this info from GM. Granted, if they took your VIN then the data does carry a bit more credibility than a brochure or an online payload calculator.
I called GM and finally spoke with a live human being who could answer my question, I had to give my VIN # so the correct information could be accessed. I remained on hold for quite a while before he returned with the answer. We were on a recorded line and after being told all of my particular truck weight and payload specifications I asked specifically if the calculation included ALL occupants of the truck (5). The answer was YES. Of course this does not include hitch weight or anything else the owner or dealership may have added after delivery.
I have the date and time as well as the name of the person I spoke with. They also generate a service number for every call for reference. So please, if anyone has definitive information regarding occupant calculations to the contrary directly from GM message me with who you spoke with and when so I can call back with that information. I don't mean to start a rock throwing contest here but if you don't have direct information from GM I have to rely on what I was told.
โOct-24-2016 03:54 PM
โOct-24-2016 03:03 PM
โOct-24-2016 02:25 PM
โOct-24-2016 10:03 AM
โOct-24-2016 09:38 AM
S&B123 wrote:Whether I'd take that as true or not depends on "who" at GM you spoke to. Unless it was a GM engineer IMO the answer is potentially suspect.Me Again wrote:Chris, I called GM and verified that on my 2016 truck the calculation includes all passengers (5) at 150lbs each.S&B123 wrote:I do not believe that is true about all occupants. It is a 150 pound driver only. The change they made was to use the actual trim level of the truck vs a stripper. Chris
Just an update.
After a lot more research trying to get info on the subject of payload and towing capacity, according to GM as of 2014 all payload stickers on the doors of their trucks include ALL occupants, 5 in my case with all full fluids including full tank of fuel. The posted 2910# on my truck is actual payload capacity "after" these items were factored in. Apparently prior to 2014 GM weighed their vehicles without full fluids and added options.
That being said we are looking at 5ers a bit less in the GVWR than the two I mentioned.
Thanks to everyone for your input on the subject.
โOct-24-2016 08:57 AM
Me Again wrote:S&B123 wrote:
Just an update.
โOct-24-2016 06:44 AM
โOct-20-2016 11:00 AM
S&B123 wrote:
Just an update.
โOct-20-2016 08:16 AM
S&B123 wrote:
Just an update.
โOct-20-2016 07:57 AM
โOct-16-2016 01:53 PM
Me Again wrote:S&B123 wrote:Old-Biscuit wrote:
GO out to your truck
Open drivers door and look on door jam
Tire Data Sticker----Yellow with have cargo carrying capacity
PAYLOAD.
Also note the info.........All Occupants and cargo must not exceed XXXX lbs.
PAYLOAD.
Both of the 5vrs you are interested in have DRY pin weight of 2000# which means when they are loaded up camp ready the pin weight will be closer to 2800#
How much PAYLOAD is listed on that Yellow Sticker????
Got enough for that amount of WET pin weight after subtracting the weight of ALL occupants/cargo (stuff inside cab/hitch in bed)???
Thanks very much!!! Shows 2910#. Was able to find out that includes one 150lb driver and all fluids to full per GM.
Another number to look at closely is the rear GAWR.
Actual rear axle weight, plus hitch and things in the bed, plus pin weight needs to equal an amount less the rear GAWR.
Chris
โOct-16-2016 01:24 PM
โOct-16-2016 09:50 AM
S&B123 wrote:
Hey all.
Been a while since I posted anything here. Just looking for some input regarding the purchase of a new (and first) fifth wheel. Currently we are looking very seriously at a Grand Design Reflection 337RLS and a Cedar Creek Silverback 33IK. We tow with a Silverado 2500HD (4.10) rear.
Any feedback will be appreciated.
Thanks.
