Filling fresh water tank
5er707
Simple question for a newbie. Other then continually checking the gauge, what is another way to know that the tank is completely full?
30 REPLIES 30
Water-Bug
Ginther wrote:
I bought one of these a year ago and it has worked great. Accurate too.
Water Meter
My fresh tank is supposed to be 68 gallons. I have NEVER needed that much water in the tank since we haven't dry camped (yet).
I usually travel with about 10-15 gallons in case we need to make a roadside pit stop / repair / clean up ....
Like others have said WATER = WEIGHT
In this case less is better.
Traveling with 15 or 20 gallons of water is one of the worse things that you can do. Either fill the tank or travel with 5 gallons of water or less. With 15 to 20 gallons of water, you have 75 to 100 pounds of weight slamming side to side and front to back. Really hard on a plastic tank and flimsy hold down screws. A full tank is stable and 5 gallons or less is not enough weight to do any harm.
schlep1967
Different answers depending on the unit. If you have a gravity fill type where you can stick the hose in the hole and fill you generally will have an air vent right there at the fill point. When it is getting close to full it will start spitting water at you. At that point slow down your fill rate to get in as much as possible without getting soaked by the overflow. If you have a hose end connection where you screw the hose on you will generally have overflow tubes/hoses coming out under the trailer somewhere. When the tank is full, water will start coming out of these. If you fill it and then start driving you will also see water coming out of these quite often.
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
attuco
And the winner is D1krueger!!
D1wkrueger
I found the best way to fill my toy hauler tank is from the bottom up. The problem is that it takes to long to fill slowly from the filling tube furnished from the manufacture. I fitted a hose fitting to the fresh water dump exit pipe. I attach my hose to the dump pipe and remove the original filling cap, as it now will act as large vent. I can fill with my hose tuned on wide open. When the water overflows from the original fill tube I know I am completely full. I also use the JAKmeter to monitor my fresh water tank level and always know EXACTLY how much water I have used and have left.
Ginther
Water Meter
2009 Keystone Challenger 34SAQ 5er
2015 Ford F250 Platinum FX4 SB CC 6.7L Diesel
Padlin
I used to jam a cut off hose down the inlet then wait for the backflow to know it was full. Had the water on too high I guess and more then once the backflow pressure blew off the hose that connects the inlet to the tank. Found that water pools up on the underbelly cover quite nicely soaking the bottom layer of plywood. Got to have overflow capacity equal to or greater then then inlow rate. Need to get one of the shutoffs bpounds shows for better hose end control.
Happy Motoring
Bob & Deb
W Ma.
12 F150 HD SCAB EcoBoost LB 4x4
14 Escape 5.0 TA
mr__ed
I have no trouble with the fresh water tank level gauge. When it reads F for full it's pretty full except being a few gallons shy of overfilled. It's a different story for the grey and black water gauges. The various chemicals in those liquids tend to make the gauge sensors in the tank inaccurate.
Mr. Ed (fulltiming since 1987)
Life is fragile. Handle with prayer.
2007 Hitchhiker II LS Model 29.5 LKTG (sold)
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition (sold)
frankwp
I walked away while filling the tank once (was just in the trailer). After a bit I heard a loud thump & the sound of running water. I then had the pleasure of removing the underbelly cover & tank, having the tank welded & replacing the whole thing. So, I don't walk away while filling anymore.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
elkbelch
Just watch the overflow
Elkbelch
2014 Ram 3500 CTD CC DRW
2011 Jayco Eagle 30.5 RLS
A teen, a tween and a Boo (crazy yellow lab)
FandG_shadow
I agree, the easiest way to find out if your are full is to watch for return from the overflow. I normally do not fill my tank if I am going from campground to campground. I will carry about 5 gal. My thought is water=weight and that uses more gas
Shadow_Grey
I let the wife fill the tank...that way I don't get wet!
'11 F150 XLT Red Candy Met. Ecoboost 4X4 Screw 5.5', Max Tow,Reese R16k 5th wheel hitch,Ride-Rite Air Springs, E Rated Tires, Extang Cover
'13 Keystone Cougar X-Lite 29RES,triple slides,Mor/Ryde suspension, Reese 5th Airborne Sidewinder, 16" E rated tires
jalichty
If you don't walk away during filling you can also hear when the tank starts getting full by the change of the sounds coming from the fill tube, very similar to filling a gas tank on a car. However, I just generally fill fairly slowly until the water starts coming out of the overflow hose in the bottom of the FW and then turn the flow off so I don't get doused when taking the hose out of the filler tube. It's not rocket science, just common sense.
John A. Lichty
Goostoff
heaterswa wrote:
If concerned with getting wet shoes, you could time how long it takes to fill a 5 gallon bucket. Then divide your tank size by 5 and multiply that by how long it took to fill the bucket. Should get you right there.
-Bryan
You would have to do this at every campground you visit since they all have different water pressure.
1993 Chevy C3500
2005 Cedar Creek 34RLTS
heaterswa
-Bryan
Me, Wife, 3 daughters, and a woof woof
TV: 06 GMC 2500HD D/A SLT 4WD / Prodigy / Reese Signature 18K
FW: 07 KZ Durango 315BH / Fifth Airborne / Sidewinder / JT Strong Arm Stabilizers
