First extended trip with 5th wheel
tim665214
2016 Jayco Eagle HT 29.5 BHDS. Approx 10K GVWR. Tow vehicle is 2016 Ford F250 6.7 Diesel Crew Cab lariat. Coming from North of Fort Fort Worth to San Antonio via 281. For anyone not familiar with this route this is right on the edge of Texas Hill country. So not flat, but not exactly mountain terrain either. It was me, my wife, 15 year old daugther and her friend as passengers.
I was really hoping to get close to 12 mpg, but overall I averaged right at 10 mpg. Does this seem about right. I also noticed that when I had cruise control on (65 mph) that on the steepest hills it would always shift down to 5th gear, and 2 times it shifted to 4th. My truck had no problem holding speed, but it just surprised me that it had to shift down like that. When I wasn't using cruise control, it never had to shift into 4th, but it still shifted into 5th quite often.
Is this what everyone else is noticing who has a similar setup?
24 REPLIES 24
larry_barnhart
Toolguy5 wrote:
Going from Cleveland Ohio to Yellowstone west gate. Down to Moab then to Arizona ( painted desert ).
Across Arizona through New Mexico, Texas , Oklahoma on I-40 back home to Cleveland.
I averaged just under 13 miles per gallon.
5er loaded is around 13,000 lbs.
Truck GMC 3500 Denali 6.6 Diesel. Average speed about 63 MPH. I get my best mileage between 58 and 63 MPH.
I also found that just over 60 mph give us the best fuel mileage.
I feel going up a mountain and then going down doesn't hurt the end result as much as like the hill country. I had a perfect DIC for mileage and fuel used until 2009 when the cluster gears went out and never was perfect after the repair. I hand do the mileage going south and this is the normal result. DIC shows 11.4. math is 11.18.
22920 combined lbs. Little less coming North each April. I don't hotrod. chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Itinerant1
That's the normal characteristic of the truck dropping a gear or 2 on a climb. Speed kills mileage along with hill climbs. I'm averaging 9.5-10 mpg pulling 15.5k through the west.
Hope you had a great time camping that's what really matters.
12v 500ah, 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts)2s4p,Panels mounted flat. Magnum PT100 SCC, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365, daily 35-45% DOD 2,500+ partial cycles.
Go_Dawgs1
Stay off the cruise control and slow down. Remember your tires are rated for 65 mph. I tow in the Pacific Northwest and I am finishing a 3 week trip to the NE part of our state. Quite a few passes of 3500 to 5500 feet on two lane roads. I run as low a 8 mph and as high as 11.5 mph on this trip (which includes flat towing). I have a 2017 GD Reflection 303 at 12,000# towing with an 04 F350 Dually 6.0 diesel. When all said and done I will probably average 10 mpg and I will be happy with that.
2004 Ford F350 Lariat 4x4 Dually
2017 Grand Design Reflection 303 RLS
Me_Again
mowingman wrote:
Just got back from our first long trip,Denton,Tx. to the Black Hills in S.D. Have a 2016, F250,6.7 diesel, towing a 26' travel trailer. Average for the whole trip was 10.7 MPG. I run between 60 and 65 most of the time.
Also recently did an 400 mile trip with our 34'Hitchiker 5th wheel, from Kansas down through Oklahoma to Texas. Same truck and we averaged 10.5 MPG. So, we got about the same results with the larger trailer. I had expected less, due to towing a lot more weight.
Look for the differences between the front of the 5th wheel and the TT. Also the 5th wheel is closer to the cab of the TV. Also a flat back on the TT vs a rear cap on a 5th will make a difference. Square corners hurt mileage.
AND WIND!
azrving
2014 3500 CTD CC 3:42 60 mph 5th gear double towing almost 15,000# usually 10 mpg. More hills 9.x. Flat easy stuff 10.x. Towing different FW 9,800 5th gear 60 mph 13 mpg.
mowingman
jrs1871
Those hills on 281 can be long and the extended pull while not steep will cause your transmission to shift down. Eleven MPG is actually pretty good but it might go up just a bit if your speed dropped a couple of MPH. We get our best mileage at 62-63 MPH. Just saying.
Toolguy5
Dan & Patty
Miss Pickles the Pomeranian Princess Rainbow Bridge 8/8/2023
2020 GMC 3500 Sierra Denali 6.6 Duramax / Allison tranny
2021 Jayco Eagle 319MLOK
BWRVK 3710 companion
Maddy the Pampered Pom @ Rainbow Bridge 12-3-2013
corvettekent
If you want better mileage you will need to slow down on the hills. I would not be hoping for much more than 11 mpg.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
stickdog
12mpg in your dreams. Just be glad diesel isn't $4.00 a gallon.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
