Fuzion rear lighting wiring?
TAS1
Went camping a couple of weeks ago and found that none of the lighting ion the garage area was working. Yes, I did check the breaker etc... lol Now, before I go tearing apart the underbelly trying to chase the problem down, I wanted to make sure the wiring wasn't run in the "attic" area. Am also open to any and all suggestions, tips, tricks and opinions.
Todd
15 Ram Megacab 3500 4x4 SRW
18 Street Glide Special
13 Harley Fatboy Lo (gone)
94 Harley FLSTC
98 TJ w/ a few mods
18 Momentum 351M
9 REPLIES 9
TAS1
It's just the interior lights in the garage only.
Todd
94 Harley FLSTC
98 TJ w/ a few mods
18 Momentum 351M
Ts1
Is it only electrical in the garage? Exterior rear lights? Cabin lights? My fuzion had a cabin light issue that was a caused by a poor connection at the rear of the fuse panel, but I did not notice that the rear door lights also were out. Keystone emailed me a wiring diagram, that helped me find the circuit.
TAS1
I'll look at the block. The fuses are under the same cover as the fuses. I'll take a second look at those too. t%hanks
Todd
94 Harley FLSTC
98 TJ w/ a few mods
18 Momentum 351M
beemerphile1
First issue I see is you're looking at breakers. The 12v system such as lighting utilizes fuses, not breakers.
Like mentioned the interior lighting is going to have the wires inside the RV, not underneath.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Y-Guy
Moderator
Moderator
Often there is a wiring block either on or near the converter/charger. Might see if the screw that was holding the wiring for the back of the garage is loose and perhaps the wire has become dislodged. That would be easy to spot which means that's probably not going to be it, but worth a look.
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
TAS1
lol yea, I have an 08 Fuzion 302. I'm bad about not looking at sigs either. Still trying to chase this problem down in a less distructive way first.
Todd
94 Harley FLSTC
98 TJ w/ a few mods
18 Momentum 351M
720Deere
I don't recall seeing a signature or I wouldn't have said that. I'm too darned young to feel this old!
2011 Ford F-350 4X4 CC LB SRW 6.7
2013 Keystone Fuzion 315
B&W Companion Hitch
1 wife 2 kids and 1 dog
lightfoot
720Deere,
reread the post and this time look at their sig.
USN EN2
2012 Ford F250 SC, 6.7L TD
2015 Voltage 3200
2004 Honda GL1800 Reverse Trike
720Deere
If you are talking about the interior lighting, the wiring is in the wall and the attic. Every model is different so it would help if you let us know what model you have.
B&W Companion Hitch
