Jul-05-2017 07:19 PM
Jul-07-2017 06:44 AM
Eyetattoo wrote:allcool wrote:Is the intake screen behind the air filter?
As others have said, make sure engine is not seized before buying a starter.
"Remove the intake screen at the front of the engine to gain
access to the flywheel nut. Use a large socket and socket
wrench to rotate the nut and hence the engine in a clockwise
direction." Confirm it spins... Otherwise a starter is not going to help if engine is seized.
Jul-06-2017 12:46 PM
Jul-06-2017 11:10 AM
Jul-06-2017 09:14 AM
dedmiston wrote:Batteries show 13.7 volts on my solar charger so there should be more than enough to turn it over? It's also plugged into the house as well.
Any chance your batteries aren't fully charged? Try jumper cables from your truck and see if it will turn over.
Jul-06-2017 09:13 AM
nayther wrote:I was able to freely spin the starter bendix. I have to work on pulling the starter off to try and turn the motor. Dang bolt are seized so I have to get some PB blaster. I ordered a new starter and solenoid from Amazon so if either is bad I have them on hand.Eyetattoo wrote:
So I pulled the generator out (what a pain in the a$$) the solonoid is sending power to the starter so I'm thinking it's the starter. I was able to spin the pinion by hand but it doesn't move when I try to start it. What do you guys think?
Assuming the engine turns over by hand/wrench replace the starter
Jul-06-2017 07:09 AM
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch • 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") • <\br >Toys:
Jul-06-2017 06:57 AM
Jul-05-2017 09:49 PM
Jul-05-2017 07:46 PM
Wild Card wrote:Is there a easy way to get it unstuck?
Starter motor is probably stuck
Jul-05-2017 07:45 PM
naturist wrote:The last time it was used was a few months ago. It's always been tough to start the first time but has always cranked.
When did you last run it? Is it possible the engine is seized due to rust in the cylinders? If you hold the power on a stalled electric motor (aka a starter) of course it will smell funny as the insulation burns up.
Jul-05-2017 07:32 PM
Jul-05-2017 07:29 PM
Jul-05-2017 07:23 PM
