Handles.....jacks and slide out....where to purchase?
Baja_Man
Hello--
Purchased a 1998 Jayco 243RKS and the handles are nowhere to be found.
I need one for the stabilizer jacks (it is NOT the bolt head type, it is the round barrel with hole on side)
I also need one for the slide out and front electric jacks. These both appear to be the same type...the head of the shaft is D shaped.
I also need an awning rod.
Where can these be found? I have found the socket head type but the ones I need as described above?
Also, where do you order RV parts and supplies online? Things like plastic vent/water/exhaust vent fittings, Max Air rain/vent covers, replacement light lenses, etc.
Thanks
2023 GMC, 3500HD, Crew Cab, 6.6L Gas/6 Speed Auto, 4X4, Standard Bed; SRW
2011 Outback 250RS - Anniversary Edition
Equal-i-zer 10K
10 REPLIES 10
Baja_Man
filthy beast wrote:
Look at the sixth one down, might be what you are looking for.
jack handle
Yes, that's the one! This is for the rear stabilizer jacks
Now, I need one for the slide out and landing gear which both have a D shaped shaft where crank handle connects. I contacted and am awaiting a reply.
I have tried all over and cant find a handle with a D shaped socket end.
I may have to drill a hole through shaft near end, place a 2" pin through it, and use the handle for this type of shaft end (which I believe is the current/commonly used type).
Thoughts?
Equal-i-zer 10K
Allworth
Adventure RV
Tweetys
Amazon Prime
E-Bay
(in that order)
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
filthy_beast
jack handle
Goody Two Shoes and the Filthy Beast
2008 Silverado 2500HD
2012 Wildcat 282RKX
You cannot make things idiot proof, you can only make them idiot resistant.
BB_TX
See if one of these is what you need.
various crank handles
ralphnjoann
Baja Man wrote:
my bad...I edited my thread....the stabilizer jack is NOT the hex head type. It is the barrel hole with a hole on side of barrel.
I have the same setup. I use a large allen wrench in an electric drill.
Baja_Man
Equal-i-zer 10K
Old-Biscuit
Good source to ID part numbers & purchase
Laurelhurst Distributors
Another good source to Id parts & purchase
PPL
Then there are these
RV Salvage
laknox
Baja Man wrote:
Hello--
I need one for the stabilizer jacks (it is the bolt head type, it is the round barrel with hole on side)
Thanks
IIRC, my scissor jacks are 3/4" hex and I know more than a few people who simply use a standard (or deep) 3/4" socket on an extension chucked up into their cordless drill. On =my= FW, the front jacks use a manual crank handle with about a 1/2" diameter barrel-shaped "socket" on the end of it. That has a small pin across the center that engages into a slot on the motor shaft to turn it. I've contemplated buying another one, cutting it off for chucking up in my cordless, but I never have. My electric slide also uses a 3/4" hex on the motor for manual operation, but I don't think I've got enough room for a ratchet handle, so carry a combo wrench in my box, to be sure.
Check RV salvage yards, too.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
Baja_Man
ScottG wrote:
Amazon is usually one of the best places to get all the little bits for RVing.
checked, no luck
Equal-i-zer 10K
ScottG
