Aug-03-2015 03:42 PM
Aug-09-2015 11:33 AM
Aug-06-2015 05:35 AM
Aug-05-2015 04:16 PM
luckeydr wrote:bpounds wrote:lpxguy wrote:
hmmm my B&W will release even with pressure on it...guess it's a design thing.
You find that reassuring? I wouldn't.
Until you use one, you would not understand.
Aug-05-2015 10:58 AM
Aug-04-2015 04:22 PM
Aug-04-2015 03:56 PM
Aug-04-2015 03:51 PM
Aug-04-2015 01:19 PM
Aug-04-2015 11:41 AM
Aug-04-2015 10:49 AM
Aug-04-2015 10:02 AM
Old-Biscuit wrote:
According to Pullrite
1)Set trailer wheel chocks to prevent forward/aft movment
Back into the blocked trailer slightly and set the parking brake while the truck is still in gear.
This action will relieve pressure on the Lock Jaw Assembly before attempting to pull the Release Handle.
2)Lower the trailer jacks to the point of just touching the ground but do not raise the trailer at this point.
3)Open the Lock Jaw Assembly by first lifting, then pulling the Release Handle towards you.
4)Lower the trailer jacks until the bottom of the King Pin Box is almost free of the top of the 5th Wheel Plate
Make certain that the bottom of the King Pin is not so high that binding on the hitch Lock Jaw Assembly would result
Aug-04-2015 09:32 AM
Obewan wrote:
...I've tried pulling the truck forward and even tried backward, raising more, raising less,...
Aug-03-2015 05:45 PM
Aug-03-2015 04:39 PM
cmeade wrote:
I am glad I have a B&W. I unpin the lever take the weight off the fifth wheel and pull forward. Friend has a Curt and he has to be centered and straight in front of 5er and no side to side angle or his won't release either.
