Dec-04-2014 08:43 AM
Dec-05-2014 08:50 AM
Ricpin wrote:
Thank you to everyone that responded.It has helped me a lot. Looks like I will need a DRW one ton truck. Is there one that is better than the others as far as maintenance.
Dec-05-2014 05:57 AM
Dec-05-2014 02:34 AM
Dec-05-2014 12:42 AM
Dec-04-2014 05:47 PM
Dec-04-2014 04:54 PM
C-Bears wrote:spud1957 wrote:
C-Bears, the only 2012 F350 6.7 that has a "published" payload of 4400lbs is a 4x4 regular cab XL. I'm sure that's not the truck you have, so your payload is probably less than 4000lbs. You could share with us the your actual payload rating on your door post. This will give us and the OP a better understanding of the variety of truck ratings and specifically an F350.
S
You are probably very familiar with your 2011 Ford specs, and you may have even looked up ones for newer Fords, I don't know. I will help educate you though. A 2012 F350 XLT 4x4 CC SRW 156" Wheel Base, with optional 11,300 lb GVWR Package, specs out with a payload of actually slightly over 4,400.
But again, none of this really helps the OP with his exact question, although it is entertaining.
Dec-04-2014 03:53 PM
S
Dec-04-2014 01:46 PM
Dec-04-2014 01:17 PM
Old-Biscuit wrote:C-Bears wrote:
I have a Montana 3725RL. If I recall your 3750FL comes in with a dry weight about 200 or 300 pounds lighter than my model, however your pin weight could be the same or slightly higher don't know for sure.
Shipping weights, or dry weights don't really mean much. By the time I picked mine up with 2nd air, Travler Dish, washer/dryer, G614 tires added I am sure it weighed another 300 pounds without our stuff.
I weigh mine every 6 or 8 months. I can tell you that I am right at my limit but not over. My pin is 23.6%.
You are going to get a ton of very strong opinions reference SRW vs DRW. You can see from my signature what I pull mine with.
If you actually want to get good advise on pulling your exact model then sign up with the MOC (Montana's Owners Forum) There are numerous ones on that site with the 3750 front living and many of them are full timers.
Good luck with your research and decision.
Weighing every 6-8 months then you have the actual numbers.
Surprised you didn't post them.
Actual numbers are more of a help then opinions.
What are your trucks numbers with and without 5vr?
Ratings..GVWR, Axle Ratings, Tire Load Ratings and the weights as scaled?
My 2007 SRW
GVWR 10,100# RAWR 6400# Rear Tire Load 6390#
My 5vr
GVWR 14,375# Actual scaled 13,830# Wet Pin 2980#
Hitched I am over trucks GVWR by 200# and right at Rear Tire Max Load Rating.
I know newer models have been 'upgraded' to higher numbers but think that a 16K GVWR 5vr would be a bit more than a SRW ratings.
Dec-04-2014 12:21 PM
Dec-04-2014 11:50 AM
bfast54 wrote:
In this particular case..I am going to toss somethng intersting into the mix.
If YOU HAVE THE ROOM........Where you park, or plan on Full timing ..You would do well to Seriously Think about a MD Medium Duty, or HD Heavy duty. Class 7..
Why in the world Would I suggest this , for your First Rig?????
Let me tell you.
I stop into the Dealers on a occasional period, and NEW Dually Diesels, all big three Are running..$50.000.00 to $60.000.00
Now, you need to go to the MD, HD Forums, some are on RV net I believe.,, but HD Forums are ou t there ..
and chat with the Guys.
You can get a Good Used Freightliner, Volvo , with 750,000 miles give or take...for some where around $20,000.00 to $30,000.00
about half the price of a New Big Three Dually.:W
The Forums will point you the way..there is a Great shop, that will help you find a Good used class 8, convert it to a class 7 Tandem axle to single axle.
Maybe a couple renewed AIR RIDE seats, some other stuff..you hav e WAY MORE truck, with a Margin of safety.
NOW this might not be the way FOR YOU...but Please do yourself a Favor, and think about it. I Personally Know 2 couples who went this way They Love it.:B
Dec-04-2014 11:25 AM
Let me tell you.
Now, you need to go to the MDT, HDT Forums,
The Forums will point you the way...:B
Dec-04-2014 11:10 AM
Dec-04-2014 11:08 AM
