Apr-18-2017 01:49 PM
Jul-06-2017 10:33 PM
IBcarguy wrote:Did you install the MORryde pinbox yourself?
I also have a new rig similar to yours and I've been fighting a severe chucking and jerking over bumps and dips in the road. I use a Andersen Ultimate hitch but I don't think the problem is caused by the hitch anyway. I tried adding pin weight, Bilstein shocks on my truck, leveling the trailer, etc. As a last resort, 3 weeks ago I bought a MORryde pinbox. This pinbox made a huge difference. It doesn't cure the chucking, but dampens it so well that I could drive all day without getting beat up and stressed out. I highly recommend it and would never own another 5th wheel without a MORryde or equivalent shock absorbing pinbox. I got a great deal from Tweety's for $485 including shipping.
Jul-04-2017 09:14 AM
ldmc wrote:
Update,
I loaded the trailer and made sure I was level. I still have chucking not as bad but enough that the wife does not like it.
I don't have the money to spend for a Trailer Saver right now, so I'm looking at changing the Pin box and maybe shocks for the trailer.
Has anyone used a Flex Trail Air pin box or a Morryde with a Curt Hitch?
Jul-04-2017 07:38 AM
Sezzell wrote:ldmc wrote:
Just bought a new 33IK Silverback and using a Curt Q25 hitch.
Trailer is 37' total length and a GVWR of 14K. Pulling with a 2017 GMC 1 ton SWB Diesel.
On the way home I noticed chucking. I'm thinking about either a Morryde or a Trail-Air hitch pin.
I'm looking for real world experience and not opinions.
Thanks for your input.
I have the Curt hitch in my 2016 Ram 3500. I recently purchased a 2006 Mobile Suites equipped with a Trailair pin box. The combination does not work well together. Chucking is so bad it will sometimes lock up your seatbelts. Cause is the combination of the Trailair pivoting lower jaw moving the Curt hitch head which has a low pivot point. Vertical motion of the Trailair jaw pivot point causes horizontal motion of the hitch head pivot point jerking the truck back and forth. Another RVer in my camping club has a Curt hitch and the MORryde pin box and tells me he tows smoothly.
Jul-04-2017 06:14 AM
Jul-03-2017 07:17 PM
Jul-03-2017 06:43 PM
Jun-27-2017 08:56 AM
Jun-26-2017 07:19 PM
Cummins12V98 wrote:
Someone recently mentioned the geometry of the hitch head on the Curt/RAM Q25. There is a lot of distance from the Curt pivot point and the hitch plate/king pin. The B&W has virtually no offset. Think about it!!!
Jun-26-2017 01:05 PM
ldmc wrote:
Update,
Put shocks on and helped some, but still a lot of chucking.
I purchased a Morryde Pin box and put it on this last weekend.
Oh my, it made it worst.
Need some suggestions on real world combinations.
Has anyone used a Curt Hitch with a Morryde Pin box?
Jun-26-2017 11:55 AM
Jun-26-2017 09:56 AM
I'm thinking since I can't return it, seeing if a stiffer box spring would calm it back down. I have a call into Morryde on this.
Jun-26-2017 09:01 AM
Jun-26-2017 07:48 AM
May-19-2017 05:22 AM
