hole in kitchen sink
antoinettek
I broke a HOT glass dish and a piece of the glass dropped in to my sink burning a hole through it... How can this be repaired with out buying a whole new sink..???
Thanks
11 REPLIES 11
agesilaus
njtony--why don't you take a picture of that sink and post it here. Someone may have suggestions.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
njtony
Our plastic sink has spider crackes in it.no leaks just looks like ****. We have been looking for as sink, but due to configuration finding replacement has been difficult. No luck yet.mcg does no offer one.
ScottG
I would just replace the sink. To me, it would be less work than trying to patch it (and it would never look good after that).
But if you are committed to repairing it, go to a marine supply store and get some patch material for the gel-coat finish on a boat.
SoCalDesertRid1
I would replace it with a stainless sink, unless it's a built-in one-piece sink/countertop...
I agree about the 2-part epoxy and duct tape.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
wvcampers
I would use a 2 part epoxy, available at wally world or lowes. I would use the epoxy to attach a piece of aluminum foil to the under side of the sink. After is set up you can color the aluminum from the top and fill the spot level with the inside of the sink. It is possible to add color to the epoxy when you mix it. Nail polish should color it well.
2017 F350 6.7 CC Lariat DRW
2018 Cardinal Luxury Edition 3250 RLX
jesseannie
Depending on the size of the hole? A two part epoxy with a 5 minute cure time will patch it just fine. You may have to layer it with some backing (duct tape would work) several small layers would probably work better than a thick glob.
Give it a try,
jesseannie
nickthehunter
Nomad II
Nomad II
I'd replace the sink with a metal one. Plastic is an accident waiting to happen, as you found out, so no use repairing it and waiting for the next such incident. Replacing the sink is not that tough.
To answer your question though, pretty much any epoxy made for plastic will fix it, but it will undoubtedly leak slightly and you will always be able to see the fix. You will have to put something behind the hole to hold the epoxy while it dries (securely duct tape a piece of mylar or something similar).
agesilaus
Njmurvin wrote:
I think I would use it as an excuse to install a metal sink. My old 1994 Terry had one. I was surprised to discover that my AF uses a plastic one. How much less could a plastic sink weigh vs. stainless?
Geez, I never thought of a plastic sink and was wondering just how hot that dish was if it could burn a hole in a SS sink.
The question is: how big is the hole?
Superbumper
Njmurvin
2020 Chevy Silverado 3500HD Duramax 4x4 Crew Cab Standard box
2011 Arctic Fox 27.5L
2oldman
Youtube
Mandalay_Parr
Might ask at the hardware store. Maybe epoxy of some sort.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
