Honda Generator EU2000
klr650goldwing
We recently bought a new Honda generator. The first time we used it all was well. A few days later we used it again. This time the generator RPM oscillated the entire time we used it. The only way I could get it to run smoothly was to apply the choke about halfway. Even after the generator was all warmed up it would oscillate without the choke applied. Any ideas on what will cure this?
2014 Grand Design Solitude 369RL
2017 F350 6.7 DRW CC LB 4X4
2012 Mercedes E550
2010 Honda Civic
2009 Saab 93 Aero Convertible
2004 Honda Goldwing GL1800
2004 Kawasaki KLR650
1966 Honda 305 Dream
46 REPLIES 46
TxGearhead
I don't use my Honda's enough. When I do I always run them dry and the drain the carb bowl. So far no issues.
I live in the epicenter of oil refining but can't buy non ethanol gas.
I've been using Startron fuel preserver. I have 50 gallons of gas in my boat that probably haas been in there 4 months.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
one_strange_tex
bob213 wrote:
Is it in ECO mode?
I have to say, this was my first thought as well. In ECO mode, the RPM's will vary based on generator load from from whatever device is using the electrical power.
one_strange_texan
Currently between RV's
Former 5th wheel owner (Montana 3402RL)
philh
And there's a recall / stop sale on EU2000... make sure your's isn't part of the recall.
Super_Dave
The choke switch on my EU2000 always seemed backwards to my minds way of thinking. What you think is choke might actually be run.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
pianotuna
Nomad III
Nomad III
It will help to use premium gas in future. Where I live premium has no ethanol.
Sta-bil is a good product but it has not, for me, cured surging. Seafoam has done so on two different generators.
Regards, Don
ACZL
Seafoam and Sta-Bil are somewhat alike, but more ways different. If you want to use Sta-Bil, use the blue or marine grade one NOT the red one. Before the days of Ethanol, the red Sta-Bil was okay to use. Now w/ the use of Ethanol, not so. Seafoam is a great product to clean and combat the effects of Ethanol. I run Star-Tron in weed eater, chain saw and snowmobiles. No problem w/ any of them. If ya want MO, use Seafoam or Star-Tron.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
RollandB
Which Seafoam product are you all using for treating the gas? Iโ€™ve used Stabil so would like to compare the two.
2013 Yukon
2021 Coachmen Spirit 1943RB
ChuckSteed
If itโ€™s brand new Iโ€™d take it back and see what they will do... something is in the fuel delivery orfice tube.
Regarding Seafoam... itโ€™s not snake oil...one of the best fuel products on the market... Iโ€™d run it all the time ... and do.. in all my yard equipment and both of my Honda 2000s to keep fuel system clean..
I also dont have to worry about fuel gumming up during non use times since I run Seafoam all the time...
Hope you get issue resolved..
Tvov
94-D2 wrote:
Dumb question here, did you flip the fuel cap to โ€œopenโ€. Both mine will do that if I forget to flip the slide switch in the fuel cap to open.
Double check about the air vent on the fuel cap. Also consider painting / marking the air vent on the fuel cap white so it is easier to see and remember.
Just a note... a "fuel related issue" with small engines is usually NOT covered under a warranty. Dirty fuel, clogged fuel lines, dirt in carburetor, etc usually is not covered by warranty.
_________________________________________________________
2021 F150 2.7
2004 21' Forest River Surveyor
jkwilson
babock wrote:
LOL...do not add Seafoam! Do not add a snake oil. If it's new, take it to your dealer for them to determine why its running lean.
Seafoam is an excellent product. It doesn't work magic, but it routinely saves tearing a carburetor apart in engines that have been sitting.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
94-D2
2018 Ram 3500 Crew Cab Laramie 6.7L, Aisin, air ride, Ram puck prep, SuperGlide 20K auto slide.
2018 Bighorn Traveler 4 slide w/Apt.
Itโ€™s not what youโ€™ve done that commands respect, itโ€™s what you do.
Happy Campinโ€™
badboy368
Whoops. Meant seafoam ...darn autofill
40' pusher,350 turbo cat, pullin a 37' trailer haulin a drag car. oh yea baby
badboy368
I am FIRM believer in the deadpan. Mine was doing the same thing and seafoam cured Mine. By all means try it.
bob213
Is it in ECO mode?
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
babock
