โOct-23-2023 07:01 AM
โJan-11-2024 02:47 AM
The ability to make a 90-degree turn is often crucial when maneuvering a 5th wheel. While an 80-degree turn might work in many situations, having the flexibility to make a 90-degree turn can be advantageous, especially in tight spaces. Consider the specific scenarios you'll encounter and the maneuverability needed for your 35' 5th wheel to ensure a smoother towing experience.
โJan-02-2024 09:20 AM
You will be fine with your B&W hitch. With the trimmed corners on our fifth wheel, I haven't come close to hitting the cab. Can't say the same for my old truck and trailer. I dented both sides of the cab. (slow learner) LOL
โDec-07-2023 11:06 AM
Just remember going backwards is not your only worry. Eventually you will get yourself into a tight fueling situation where turning sharp is the only way out. I would rather have the hitch slide back automatically than have to stop in a crowded high stress situation, get out and unlatch the hitch, then get back in and pull forward to move the hitch. And after maneuvering out of the tight spot, find a safe location to stop and slide the hitch back again.
โNov-28-2023 06:40 PM
I have a short bed GMC and a B&W manual slider. I normally don't use the slider. But when I need it I need it.
We boondock in out of the way places, we may be miles down a dirt road. If I have to go through a large dip it's nice to slide the hitch back so the tailgate wont hit the bottom of the trailer when the front of the truck drops down. It's also great if we have to hitch up at an angle,
The trailer is also much more maneuverable with the hitch slid back, comes in handy when getting into tight spots.
โNov-28-2023 03:24 PM
like stated already, you don't need 90* turning until you do !
the long beds not only give you ability for full turns, larger fuel tank, better ride ( from longer wheel base). it also gives you more storage.. I will NEVER go back to a Short Bed when towing
โOct-24-2023 02:17 PM
bpounds wrote:
I have a long bed, and I have turned 90 degrees one time - in a parking lot when it was all new and I wanted to be sure it was possible. Never needed to in real life.
Still, glad to have a long bed. If you have a cross-bed tool box, or some kind of rolling bed cover, there isn't much space left in a short bed truck, especially since all your gear needs to sit below the bed rails while towing. Pretty sure my next truck will also be a long bed.
โOct-24-2023 08:09 AM
โOct-24-2023 07:07 AM
โOct-24-2023 06:07 AM
โOct-24-2023 05:31 AM
Nv Guy wrote:
What will "get you" is if you are turning while the truck is going up a slight grade while the trailer is facing down.
Think of pulling out of a steep driveway while turning to enter a lane of travel.
Same thing if you are cutting it sharp while backing into your RV space next to your house- up a 8% grade.
โOct-24-2023 04:15 AM
โOct-23-2023 11:01 PM
phillyg wrote:
You don't need to get to 90 degrees, until you do. My experience has been that auto sliding hitches for short bed trucks are important.
โOct-23-2023 09:32 PM
โOct-23-2023 05:27 PM
op wrote:
I really want to do with the standard B&W hitch in my F-350 with the 6'11" bed.
