โJul-15-2015 06:43 AM
โJul-18-2015 11:58 AM
newman fulltimer wrote:
empty the fridge and dont worry about it
โJul-18-2015 08:29 AM
โJul-15-2015 02:55 PM
cmcdar wrote:laknox wrote:cmcdar wrote:
Good question!
I do have solar, how long will the fridge run on a 20lb tank of propane, anyone know?
Thanks,
Caryl
Question is, "how =much= solar"? ๐
Lyle
I have a 100 watt panel and two 6 volt deep cycle golf cart batteries wired in series (12v).
Why, how much dc power does a fridge running on propane draw?
โJul-15-2015 02:18 PM
Good question!
Thanks,
Caryl
Lyle
โJul-15-2015 11:47 AM
cmcdar wrote:
Good question!
Thanks,
Caryl
โJul-15-2015 11:46 AM
Bigmoss wrote:
I have my used 5er still that I've had for three years and love it. I bought it for hunting but we take one trip away with it a year normally.
This year we have decided to take two trips and it will be at the same RV park 10 days apart between trips. The owner of the park has agreed to let me leave my 5er there in the storage area for the ten days instead of haling it home and back for no reason as I am in Canada and they are a 5 hour pull to the US.
My question is I have never been without shore power so I don't run the fridge on propane very often. If I leave a full 30lb tank of propane in the 5er am I correct to assume it will run the fridge for 10 days no issue so I can leave some things in it ?
Thanks
โJul-15-2015 11:44 AM
โJul-15-2015 10:56 AM
colliehauler wrote:NC Hauler wrote:Irrelevant if you disconnect the battery the light will be off.korbe wrote:NC Hauler wrote:Bigmoss wrote:
Thanks guys the battery never crossed my mind at all and you guys are correct it will die. I guess I will just empty the fridge and disconnect the battery before I leave as I will leave the fridge door open and the light will stay on if I don't.
....remove light bulb:)....I'd still disconnect battery(ies), due to other voltage draws as alluded to earlier.
When my frig is turned off, the light will not come on while door is open, even when on shore power or with the battery on.
Same here...but I thought OP said he had "older" unit....on older units I could turn fridge off and light would still come on if door open.
โJul-15-2015 10:42 AM
โJul-15-2015 08:45 AM
TucsonJim wrote:cmcdar wrote:
Good question!
Thanks,
Caryl
I'm guessing approximately 30 days based on usage we see.
โJul-15-2015 08:43 AM
cmcdar wrote:
Good question!
Thanks,
Caryl
โJul-15-2015 07:58 AM
โJul-15-2015 07:40 AM
โJul-15-2015 07:23 AM
