How long will it last ?
Bigmoss
I have my used 5er still that I've had for three years and love it. I bought it for hunting but we take one trip away with it a year normally.
This year we have decided to take two trips and it will be at the same RV park 10 days apart between trips. The owner of the park has agreed to let me leave my 5er there in the storage area for the ten days instead of haling it home and back for no reason as I am in Canada and they are a 5 hour pull to the US.
My question is I have never been without shore power so I don't run the fridge on propane very often. If I leave a full 30lb tank of propane in the 5er am I correct to assume it will run the fridge for 10 days no issue so I can leave some things in it ?
Thanks
2016 Ford F-150 Screw Lariat Short Box
2015 Jayco Eagle HT 27.5 RLTS
Reese 30051 Hitch with Revolutionary Pin
21 REPLIES 21
Dtank
newman fulltimer wrote:
empty the fridge and dont worry about it
Yes - Empty the fridge, shut it down & leave the fridge doors open.
Battery & propane to trlr = off.
You will be way happier when you return!..;)
Fishbreath
Having had food left in an RV fridge without power I can tell you that it is not a good situation to be in. The smell will penetrate the surrounding insulation and make it near-impossible to salvage.
Plan to consume the food by the end of your trip and you should be good to go.
Good luck
Bill
laknox
cmcdar wrote:
laknox wrote:
cmcdar wrote:
Good question!
I do have solar, how long will the fridge run on a 20lb tank of propane, anyone know?
Thanks,
Caryl
Question is, "how =much= solar"? ๐Ÿ™‚
Lyle
I have a 100 watt panel and two 6 volt deep cycle golf cart batteries wired in series (12v).
Why, how much dc power does a fridge running on propane draw?
Didn't know of "solar" meant a trickle charger, or something more serious. Definitely "more serious". ๐Ÿ™‚
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
cmcdar
laknox wrote:
cmcdar wrote:
Good question!
Thanks,
Caryl
Lyle
HTT: 2007 R-Vision Trail Cruiser c191
TV: 2010 Nissan Titan Pro4X Crew Cab
laknox
cmcdar wrote:
Good question!
Thanks,
Caryl
Lyle
momentum_rv
Thanks
It sounds like you are not going to be doing this but if you or someone else is thinking of leaving your refer running on propane while away for several days, just remember one ignition error and it will be off 'til you return.
2015 Grand Design Momentum 385TH
2015 Ford F-350 DRW 4x4 Lariat
toedtoes
Even if you have enough power to manage, my concern would the "what if" scenario. If something goes wrong and you lose power to the fridge, you could be returning to a new life form. I'd rather lug the food than come back for vacation to that.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
NC_Hauler
colliehauler wrote:
NC Hauler wrote:
korbe wrote:
NC Hauler wrote:
Bigmoss wrote:
Thanks guys the battery never crossed my mind at all and you guys are correct it will die. I guess I will just empty the fridge and disconnect the battery before I leave as I will leave the fridge door open and the light will stay on if I don't.
....remove light bulb:)....I'd still disconnect battery(ies), due to other voltage draws as alluded to earlier.
When my frig is turned off, the light will not come on while door is open, even when on shore power or with the battery on.
Same here...but I thought OP said he had "older" unit....on older units I could turn fridge off and light would still come on if door open.
Irrelevant if you disconnect the battery the light will be off.
agree...I was just for silliness stating that you could remove the light bulb and light won't work either...It's obvious there will be zero power to the unit if battery is disconnected..
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
colliehauler
cmcdar
TucsonJim wrote:
cmcdar wrote:
Good question!
Thanks,
Caryl
I'm guessing approximately 30 days based on usage we see.
Wow - Thanks! That is good to know.
TucsonJim
cmcdar wrote:
Good question!
Thanks,
Caryl
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
Bigmoss
Correct if I turn my fridge off and leave the door open the light still stays on
NC_Hauler
B&W RVK3600 Hitch
cmcdar
Good question!
Thanks,
Caryl
