โJun-28-2015 06:14 AM
โJul-07-2015 10:50 PM
โJul-05-2015 01:13 PM
Campinfan wrote:
So I have Lippert Axles and there is a rubber cap covering a zerk fitting. I am thinking these are bearing buddies or whatever (Actually EZ Lube)...but do I just squirt a few pumps of grease into this every year or so. Trailer is one year old with 2500-3000 miles on it. Any suggestions?
โJul-05-2015 08:10 AM
Hannibal wrote:
I think your assumption is good to go. Give the tires a good visual check including the date code. We're loading up for our trip this morning. Y'all have a save and fun trip!
โJul-05-2015 04:37 AM
โJul-04-2015 11:30 AM
bpounds wrote:
Not sure what you mean by a rubber cover over the lugs. That sounds like a hub cap on a truck. Your Cougar wouldn't have that as far as I know. My wheels look exactly like your pic, except that I have removed that chrome center cap.
โJul-04-2015 10:13 AM
โJul-04-2015 08:37 AM
โJul-04-2015 07:51 AM
โJul-03-2015 06:53 AM
โJul-03-2015 05:06 AM
Hannibal wrote:
I don't know what GM uses but, both Ford and Dodge come with a screw type bottle jack that's perfect for this and you'll always have it with you. I put one of my leveling 2X6" boards under it. My axles are under the springs so I put the cup under one of the U-bolts. The long handle is easy to turn with the tire iron standing beside the trailer. Just a thought...
โJul-03-2015 04:43 AM
PokerCamper wrote:bpounds wrote:
The jack you have would work fine too. Just put it right under the leaf spring, directly under the U-bolts, and jack one wheel up at a time. No need to use the jack stands if all you are doing is pumping up the EZ Lube fittings. You won't be placing your body under anything, and you won't be removing the tire/wheel.
bpounds, I found this image on the rv.net forum and presume this is what you're describing. I'm a visual person and haven't yet crawled under my RV to take a look at the wheels, but apart from the fact that this shows a bottle jack instead of a floor jack, I'm guessing this is the correct way to do it?
I thought about using the Trailer Aid ramp this first time for the very reason you mentioned, to get practice with it in case of roadside need (have read too many posts about Chinese bomb tires). But in case I find it too much of a PITA, I might just use the jack on the other side once I've gotten some practice positioning the RV on the ramp.
โJul-03-2015 04:38 AM
PokerCamper wrote:
Thanks everybody for all the help. I'm planning to do this on Saturday and looking forward to learning something new about my RV. ๐
โJul-03-2015 04:34 AM
โJul-02-2015 07:13 PM
