how to get info if you are dumb?
coon_creekers
well, we have narrowed it down to a fver at least! seriously, we have no idea what manufacturer is the best, or worst. is there somewhere we can find out? yes, we know what options we do, and don't want. but aside from personal exp. which we have none, how does one find a rating of good and bad? I am so confused right now :h
23 REPLIES 23
TheAmRheins
Once you have a few specific manufacturers in mind, you should take a trip to northern Indiana and go on some factory tours. What you see could make a "this one or that one" decision easier!
Ken & Kathy
Ruben(the cat)& Tiadora (nother cat)
2003 Chev 3500 D/A Dually
2009 Landmark Augusta
RoyB
Don't rule out doing the rental of something you both like. Nothing better than spending a weekend in a rental unit finding out what may work best for you all...
Just going down and buying something is one thing but when you hit the road with it will really start showing what your needs/likes are going to be.
My hat is OFF to those that can manager those big rigs going down the roadway. They are hugh, expensive to operate, and to me can't be all that enjoyable in the transit mode. Too much for this ole country guy to manage. I also think you will always have to have DEEP POCKETS to keep your head above waters.
The only expenses we have is buying a couple of batteries and a couple of tires ever five years or so. Insurance and licenses is not bad at all for our OFF-ROAD size POPUP I have. I have all the modern appliances the big rigs have just abit slacking on the move around inside space. Everybody wants to go BIG - The bigger the better it seems. Our camping lifestyle likes the 24-26 size trailers.
Of course we are in it for the camping mostly off the power grid places and not for the full time living in the HOME ON WHEELS thing. There is a big difference in lifestyles here...
Must be a hugh nightmare for you guys trying to get it right the first time. It is hard buying your last RV first. You may end up going through two or three of them before you get the one you like the best. i.e. the more deeper the pockets are the better I reckon...
just some of my keeping sane thoughts here...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
missourijan
Do lots of research, read lots of rv forums. Look at owners forums, like for our brand is www.suitesowners.com, there's an Excel owners forum, Jayco forum, Montana forum, etc. You can see what kind of issues real owners are having. If this is your first rv, buy a good quality used unit with a floorplan that looks liveable to you. You will not know what you like and don't like until you spend time in it. Buying a used unit prevents you from making a mistake, keep it for a year, if you don't like it then you can buy a new one with the floorplan that suits you best.
rvonthegogo
Right on point Motorcycle Jack ๐Ÿ™‚
Bayley
We spent months and months researching 5th wheels. We obviously wanted the most we could get within our price range.
We finally zeroed in on the Arctic Fox from Northwood Manufacturing. They build their own frames and seem to pay close attention to detail when building their units.
They are a little heavier than most but the quality you get is worth dealing with the extra weight.
So far we are very happy with our 5'er!
Tony, Darlene and Bentley
2013 Ram 2500 HD, Turbo Diesel, Exhaust Brake, TMPS, Tow/Haul, RideRite Airbags.
2014 Arctic Fox 295K Silver Fox Edition
Semper Fi
Tony, Darlene & the boss Bentley!
2013 Ram CTD, Ride-Rite Air Bags, B&W Turnover Ball and Andersen "Ultimate 5th Wheel Connection".
2014 Arctic Fox 29-5K 5th wheel with Reese Airborne Pin Box.
cdlaine
Leigh...
Our rule.... after you have done all of the above,
get the one your wife wants. Simple.
Charles
2003 2500HD, 8.1L,CC,4.10,2WD,Allison
Standard bed
Ride-rite air bags
Prodigy
Husky 16K sliding
2013 Artic Fox 29-5T Silver Fox Ed.
Pin wt.(CAT Scale) 2660#
5th (Cat Scale) 12600#
I'll want the Frim Fram sauce with the Ausen Fey with
Chafafa on the side.... Nat
laknox
All good advice here, so far, but one thing has been left out. Look at FWs =first= and settle on what you like, based on your camping desires/needs, THEN tailor the truck needed to tow that FW. If it turns out that you might need a Freightliner Sport Chassis or even an HD (semi) tractor to tow it, and aren't comfortable with that, then set your sights lower. Do =not= listen to what the salesmen tell you a given truck will tow; they're as likely to tell you that the newest 1/2 ton trucks, with all the bells and whistles, will safely tow a 40' FW. Forget "towing capacity" when shopping for FWs; it's all about =payload=; how much the truck can =carry=. You're =carrying= the front of the FW, same as if the bed were filled with cement block, and that's the "weak link", as it were. Dozens of threads on here regarding weights; pick 10 or 15 and read them, and you'll pick up most of what you need to know.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
MrVan
Also consider the cost and inconvenience of having to return the RV to the dealer multiple times for warranty repairs. And if needed parts are not immediately available you may not be able to use your RV for weeks or even months. Those costs are not compensated under any warranty program. If and when you buy ,,,,find a dry campground and a full service campground as close as you can near the dealer and spend enough time in each type of campground to fully exercise all parts, features and appliances in the RV. Also make sure there are good tires on the RV before you buy. ST tires are not good tires.
anaro
Honestly all manufacturers make good trailers and all manufacturers make junk. The key is to find a manufacturer that stands behind their product and a good dealership to work with. To help determine this, go to owners forums and lurk a bit. Do remember that more people with problems tend to post than those who have no issues. Follow the themes of the posts and throw out ones that appear to be rants from posters with one or two posts on that forum.
The best thing to do is go to an RV show where you can easily see a lot of rigs from a lot of manufacturers. Compare trim levels, amenities, how comfortable and user friendly they are. Take notes and go out them into a spreadsheet. Once you decide what style of floor plan you like for your needs, then you can compare across brands. Compare price, weight, tank size, or any other option that is important to you. Once you narrow it down to one or two, then you can do pros or cons, post on an owners forum and ask about the good and bad for that 5er. WhY do they like or dislike about it.
When deciding what floor plan you like, sit in them, imagine your usage, i.e. moms clothes in that closet, dishes in this cabinet, kids toys in that drawer etc. Act out your daily activities (ie cooking, watching tv, walk around each other in the unit.) Ask to see the unit with the slides in so you can see what is and isn't accessible. What is important to you for accessing on the road? In my current tt, we can't get to the bathroom if the slide is in or the pullout sofa is out at night. Things we didn't think about that we will watch for in our next unit.
2014 Silverado 3500 Duramax, SRW, Crew Cab, 4WD
2014 Palomino Sabre 34REQS -
2011 Crossroads Zinger ZT26BL - sold in 2014
motorcycle_jack
What's best for a week ender isn't what's best for a full timer. What's best for a family of 4 isn't what's best for a young couple or an older couple. What you need to do is determine your price point, look at some manufacturers in that price range, pick a floor plan and go check one out. Spend an hoยจr or two in it and imagine living in it. Where do you put this item and that item, find there places and check if they fit. When you can answer those questions you'll know which one is "best".
John
"Motorcycle Jack"
Life time Good Sam Member
Blog: My RV
5th Wheel Blog
Full timing isn't "always camping". It's a different life style living in an RV.
ol_Bombero-JC
ed6713 wrote:
RV Consumer Group
It will cost you a few bucks to join, but if you're looking for an unbiased opinion on an RV, this is the site for you.
Considering how much. $$$$ you're about to spend, this is pocket change.
Good hunting. There are more junk products then quality products so be careful in your search.
Ed
Note *IMO*.
When I was looking for my first 5th wheel, I thought that would be a good idea.
Then (after purchasing the product), I found they admitted it wasn't really based on "consumers" - and for *new* 5th wheels, they also admitted they had *no* first hand -or consumer- information.
(They simply "evaluate" the mfgr specs and info).
I considered it worthless, and inaccurate guesswork.
Real experiences by owners -and my own observations- were a much better "guide".
OP - go out and look at the manufacturers offerings yourself.
For openers, that's more than the Consumers Group does.
See what you like and what you don't.
Spend time in the ones you like. Open drawers & cabinets, etc.
When you have narrowed your choices - try some searches on forums (like this one) - and owners forums (sometimes by brand and/or on Yahoo Groups)
See what owners are saying. Positive/negative, good-bad-ugly?
Your YMMV...;)
Aridon
Price - determines manufactures you check out
Then floor plan reduces that number
Finally go look at them and do the touch and feel test
After that hop on the internet and post here for help on which to choose.
2019 Grand Design Momentum 395
2018 Ram 3500 DRW 4.10
2014.5 DRV Atlanta (sold)
2008 Newmar 4330 (Modified) Sold
spindrift
Are you buying the fiver to match your truck, or vice versa? Get a subscription to Trailer Life. Seek out RV shows and be prepared to walk, walk and walk some more. It took us more than a year before we found what made us happy.
'12 F350 KR CC DRW, with some stuff.
Redwood 36FL
bobx2
If only it was as easy as, the more you pay, the better quality you get. Unfortunately, that is far from the truth. Many rigs are far over priced, based just on their brand name, and/or popularity, just like most anything else you buy these days.
Hours of research online about different brands and how they are constructed is where I have always started. When I narrow it down to a few different brands, then I look at floor plans. Then the fun really starts when you go out and actually walk through the models you have selected, and get to look, touch and feel the differences. When you think you have found "the one", you will see something new that you like and hadn't seen or heard of before....
Becky, Bob, Taylie and Bode
2009 Silverado Duramax/Allison
2014 Heartland Sundance XLT 245RL
2015 Polaris Sportsman 570 Touring - Mine
2015 Polaris Sportsman 570 Touring - Wifes
