Jack Points on 5th Wheel?
5thwheeleroldma
Does anyone really jack up their wheels by the frame? I tried that once and had so many blocks stacked up under the jack, plus you have to have two jacks, that it was really shaky and dangerous.
I guess they are afraid you will damage the axle tube, but that is what I have ended up doing. I put a bottle jack close to where the U-bolt attaches to the axle and jack there. I know it is not recommended, but I think you will eventually kill yourself trying to jack up the frame.
I suspect the axle people are just covering their donkeys. Any brilliant ideas out there? I used to be an engineer; why not just manufacture the axle with a flat plate (for jack) welded on close to the U-bolt location on each side of the axle?
19 REPLIES 19
Randu
Only by the frame for last 10 years. MFG recommendation's on last 3 trailers I have owned. 2 jacks if removing both wheels for bearing or brake work, 1 if just pulling 1 wheel. Randu
2017 Chevy 3500HD SRW Crew LTZ
4x4,Duramax, Allison.
2017 Jayco North Point 381DLQS
Previous: 2000 Travel Supreme
2005 Newmar Kountry Star
2008 Mobile Suites 36TK3
naturist
fj12ryder wrote:
Yep, I put the jack under the spring perch also. I do believe the warning not to jack on the axle is just a CYA so people don't try jacking at an unsupported part of the axle, and bending it.
Yeah, I can see people doing something like that. I mean, hey, I've got a 10 ton bottle jack, the TT only weighs 5,000 lbs fully loaded, all I need to do is put the jack smack in the middle, I can pick up the whole thing at once, right? What can possibly go wrong???
Seriously, somewhere, somewhere there is somebody dumb enough to try it.
fj12ryder
Howard and Peggy
"Don't Panic"
donn0128
Grrr stupid park WiFi double post
donn0128
To change a tire you always place a Jack under the spring perch. To lift the entire trailer you need several Jack stands on each side.
