Kingpin Tripod Stabilizer
Piddlers
As stated in another thread we are making the switch from travel trailer to fifthwheel and I'm sure we will have more questions to come.
Would be interested to hear from everyone regarding kingpin tripod stabilizers. Pros and cons please.
Thanks in advance for your input.
Regards,
The Piddlers
29 REPLIES 29
Cummins12V98
jdb7566 wrote:
If you have a rubber bushed pin box like a Mor-Ryde, they are worthless.
TRUE!
These are even worse. Up and down plus front to back movement!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
jdb7566
kennethwooster
Iโ€™ve used one for years. My Cameo has Big Foot hyd stabilizers. Very steady but with tripod no movement. Another reason I use it it keeps me from banging head on king pin. Iโ€™m on blood thinners and have been to drs more then once.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
whiteeye42
Don't waste your money I have 2 of them and the only thing they are good for is catching your foot on when you go around the front of the trailer or when you are getting into to the front compartment
Me,Wife two boys and two dogs
2008 Dodge Ram Quad Cab 4x4 DRW 6.7 cummins
2008 Jayco Eagle 341 RLQS 37' with B&W turnover ball & companion hitch
using rotochoks
add state map
CabinetmakerII
We have JT Strong arms, X Chalks, and air ride king pin. Suffice to say my DW thinks the tri pod makes a difference therefore I set it up when we are staying for more than a week. Happy wife, happy life.
Cabinetmaker
2021 DRV 39 DBRS3
2017 F-450 4X4, Riece 24K Hitch
2011 F-450 4X4, Companion 18K Hitch, Air Bags (Retired)
2012 Cyclone 3800, 5th Airborne Kingpin (Retired)
2018 Polairs 1000 XP Side by Side
allen8106
Regards,
The Piddlers
I have a king pin tripod but haven't used it since I installed JT Strongarms. Best modification I've ever done.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
Nicholsfamily05
We use one every time we go out.
Our trailer is 42โ€™ and itโ€™s a front living room so lots of movement over the kingpin.
Then add in our two kids and 2 65lb dogs and well we are moving and bouncing.
We tried to do it without that but kid moves upfront you feel it in the back.
So we put the stand out and wow it made a world of difference.
We have the 6 point hydraulic leveling system with X chocks in the wheels but movement was there.
We also when stopped for a while will put two jack stands under the rear frame and it helps even more.
So for us it is a great addition and well worth the money and space it takes up.
2016 Ram 3500 4x4 Big Horn Crew Cab, SRW. Cummins Turbo Diesel Automatic 68RFE Trans
50 gallon diesel Transfer Flow tank with the Traxx 3 system.
2017 Sierra FLIK 5th Wheel
42' Front Livingroom, 15K
Hydraulic level up system
Cummins12V98
These blocks I made do make the RV MORE stable.
ependydad
Piddlers wrote:
Thank you to everyone - I appreciate your 2 cents! Nothing better than advice from actual users.
There are a few more steps that you can take to stabilizing the RV:
http://learntorv.com/shake-shake-shake-rv-stabilization/
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
Piddlers
filrupmark
I had one also. Bulky and just a general PIA . I now have JT'S and they are great .
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
laknox
rhagfo wrote:
ford truck guy wrote:
The only pro I can think is that it was easy to get rid of when I realized that it was worthless... #saveyourmoney ๐Ÿ˜‰
Other than tossing in the trash how did you get rid of it??
Since I now have JT Strongarms have no need for it.
If you have a tripod with tubular legs, you could have made your own stabilizers out of it. :B
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
Cummins12V98
One came with our 02 Avion Platinum. Tried it, gave it away.
I get a kick out of the people that have one under an air bag kingpin.
ACZL
JT Strongarms and forget it! Had a Tri-pod, was okay, but then got the JT's and WHAT a difference. Sold the Tri-pod, then the trailer later. Now have the 6 point, some wiggle but okay in my book!
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
