Landing Gear
skinnyme
When traveling down the road, do most people remove the pads/mud sills from the landing gear or do they leave them attached? This is my first year with a 5th wheel. Thank you.
7 REPLIES 7
Splashers3
I've also never seen anybody with a 5th wheel remove them.
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
mtofell1
If those come into contact with anything when fully retracted you've got bigger problems.... as in the rear axle of your truck and half the bed will be missing ๐Ÿ™‚ ๐Ÿ™‚
mhardin
Mine have never been removed.
2013 Ford F-350, 4x4, Crew Cab, Long Box.
2001 Jayco Eagle 266 FBS.
2014 Heartland Elkridge 37 Ultimate.
valhalla360
Nomad III
Nomad III
Never even seen anyone remove them...so no.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
fj12ryder
Never removed mine, or needed to.
Howard and Peggy
"Don't Panic"
jdc1
If they retract far enough, leave them on. Half of the pull-trailers need to remove them, but 5th wheels usually do not.
RoyF
Mine stays on. I have never seen or heard of one being removed for travel. They aren't going to come into contact with anything during travel if they are fully retracted.
