Laundry sheets and bugs on the front cap.
stro1965
I read it here, and didn't really believe it until I tried it today. WOW! Never before have bugs come off so easily! Thanks!
2018 Ram DRW 3500 6.7
2019 Keystone Alpine 3021
19 REPLIES 19
Veebyes
83trekker wrote:
Should you use a pressure washer on a 5th wheel with fiberglass sides or is that to hearsh and only use bucket water?
One of those electric 1500PSI pressure washers are relatively harmless. Mostly useless too. Best thing is a bucket of soapy water & a brush.
If you want to risk damage to decals, use a 3000PSI or 5000PSI washer. Do all kinds of damage in seconds in the wrong hands.
2007 Alpenlite 34RLR
stro1965
The only risk is peeling off decals as I see it. And obviously stay away from seams with any strong water pressure.
83trekker
Veebyes
The cleaners that work well to remove bugs are more than likely going to strip the wax off too. Less wax, more stubborn the bugs, the more cleaner, less wax left on, the cycle gets worse.
Use a good wax then wash with a non wax stripping soap & water.
Bottom line, there is no easy way to deal with bugs on the front cap though washing them off before they bake on real good helps.
N-Trouble
I have a wash mit where one side is soft wool material and the other side is a fabric mesh. The fabric mesh side does a great job of scraping the bugs off. Something like this: http://www.freewtc.com/buy-2-in-1-synthetic-wool-wash-mitt-35826/
I agree don't use anything that will remove wax as you'll have to re-apply much sooner.
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
MTPockets1
Bunklash wrote:
Nutinelse2do wrote:
Are you all using DRY dryer sheets or WET ones?
Wet ones. And I too vote against the spray and wipe cleaners. Just use regular car wash soap.
If it gets to the point where it won't take a shine, check this out:
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25818736/srt/pa/pging/1/page/1.cfm
Many thanks to 4X4van. I used his technique a few weeks ago, I'll report on how it holds up.
Love this forum!
The above is a good recommendation on products to use to restore your finish.... The absolute best I've found to 'keep' your shine 'and' make it easier to remove the bugs is a product called Rejex... I was skeptical for a couple years, then I was given a bottle... Applied to front and rear cap, and one side, then had to order more. Works better than any wax I've ever tried, and I've tried most of the good ones, but ReJex tops all of the wax jobs... Check it out HERE
2012 3055RL Big Horn - Dexter upgraded axles - G rated LT Tires
MorRyde, Genset, Dual Panes, 2 A/C, Yeti Package
2013 F350 DRW 4x4 Crew King Ranch
Ric_Flair
I also found the dryer sheets to not be very effective. Still looking for the substitute for elbow grease. Haven't found it yet....
2013 GMC 3500 DRW 4x4 SLT Duramax
2013 Road Warrior 415 Toy Hauler
2013 Kawasaki 4010 Mule
jnharley
We also remove the bugs after every travel day. We just use our long handled brush and a small bucket of warm water. Tried the dryer sheets once but did not like the residue it left behind. Took longer to get that residue off than it did the bugs,
2015 Dodge Dually
2012 NuWa Discover America 355CK
Duck
I always make washing the bugs from the front cap as part of my setup procedures. Even love bugs will come off if you soften them up with water and then a scrub brush. Takes around 15 minutes. Simple Green is a great cleaner but will take the wax off. The ideal situation is a heavy rain storm around 15 miles from your stop that stops as you pull into the cg. Most all bugs come off between the rain and the air hitting the front of the cap.
Don
08-FORD F350 PSD
13 Bighorn 3055RL {For Sale}
Bunklash
Love this forum!
USAF retired
'08 Cameo F35SB3
'02 F350 PSD, CC, SRW, 2WD
One terrific wife
Bunklash
Love this forum!
USAF retired
'08 Cameo F35SB3
One terrific wife
Nutinelse2do
Living Our Dream
MTHRSHP - 2006 KSDP 3912
Cummins 350ISL...Spartan Chassis
ESC POD - 2019 Ford Ranger XLT FX4
Zippy Scoot- 2018 Honda PCX 150 on an Overbilt Lift
Shredder at the Rainbow Bridge - You Will Always Be With Us
Tiger4x4RV
I spray the front of my class C with water (or do this cleanup on a damp foggy morning), then did a long-handled mop into bug-removing windshield washer fluid, give the bugs a quick rub with that, and quickly wash it off with water. So far no problems and no climbing up to reach it with the dryer sheets.
2006 Tiger CX 4x4, 8.1 L gas V-8, Allison 6-speed
RVUSA
I just spray the front with pam and then hose it off when I get where I'm going.
