Legs up/ Legs down?
Jim102
For a one night stop can you leave your 5th connected and all legs up? Just disconnect the power cable to the truck and call it a night?
Thanks,
Jim
2018 Jayco Precept 29V Class A
Air Force 1969 - 1973
23 REPLIES 23
Vette_Racer
I leave everything hooked up and no legs down, doesn't bother us a bit if it moves a little, shore power hooked up, no problem, just put the slides out and go.
KE5NCP
2016 Ram CC Dually, 2011 HitchHiker 349 RSB DA, 2018 Wrangler unlimited Rubicon
Blazing_Zippers
On our TV, the electrical stays charged when the engine in off---So, I disconnect the plug to keep the TV battery up. I also, drape a glove over the steering wheel when I do this to remind me. Once in a while, I do drop the front legs to stabilize the rig, but usually just level it with a couple wooden blocks if we're just overnighting it. The glove on the steering wheel jogs my memory that something needs to be checked before leaving.
It has worked so far.
rhagfo
DHCamper wrote:
Thanks,
Jim
Not that familiar with GM trucks, my power cable isn't live when the ignition is off. If yours is the same you can just leave it connected.
I chuckle at this, once I had a host site that lost one leg of the 50 amp feed, the leg my converter is on, used a bunch of lights and furnace a bit. Well 2:00 am the 5er battery was drained enough that the Propane alarm went off. Once I realized what the issue was my solution was to plug the 5er power into the truck!! Two big batteries to start the diesel not an issue for parasitic and a few lights in the morning.
wilber1
Sure, when heading south for the winter we don't unhook for six days. I put the jacks down to stabilize (not level) the trailer but there is no need to. If you do, just do it before you put the slides out.
If the spot is a pronounced up or downhill, you might have to disconnect.
"Never trust a man who has not a single redeeming vice" WSC
2011 RAM 3500 SRW
2015 Grand Design Reflection 303RLS
DHCamper
Thanks,
Jim
tinner12002
Old-Biscuit wrote:
YES..........
Legs Up or Down OK
X2...and to add to that, unless your out of level in an extreme manor or you plan to run out all slides then I would at least run legs down but with no slides out or in an extreme off angle, which I wouldn't think a person would stop in a spot like that anyway, leave legs up and don't worry about frig!!!!! I feel the OPs post was to try and keep stop over as easy and simple as possible which did not include unhooking or disconnecting anything.
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
djousma
I usually just go ahead and disconnect, and level. I used the opportunity while disconnected to go refuel without the trailer in tow.
Dave
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
2017 Forest River Cardinal 3850RL
Strabo
Doesn't matter to me for one night.
04' F350 PSD TB SC FX4 XLT, TH-04' 32' Sandpiper Sport Fifthwheel WB Dual Axle
07' Rhino 686 SS106-ITP-AFE-BRP-T4-CDI-KIBBLEBWHITE-CVT-TSTICH-Ridgid LED LightBar-HID Conversion Kit-LIVEWIRE
04' Honda 250 Sportstrac quad
05' Honda 400 Ranchers quad
Bionic_Man
I have done it a number of times. Even putting the slides out. Trailer is now 15 years old, I don't know what the concern with this practice would be???
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
Veebyes
Depends. Depends on how level the Walmart carpark is. If available I'll look for a slight downhill so that lifting the weight off the truck, to reduce the shake a little, brings the trailer sort of level.
2007 Alpenlite 34RLR
Dave_and_Sue
Depends on how tired I am. Get it close drop fronts just a touch,unplug from truck and let ot the kitchen and on bedroom slide and hit the rack.
2011 Ram 3500 Dually Mega Cab
2016 Chaparral 370FL
korbe
We will often stay hooked up when we are just staying over night and then moving on down the road. Close to level, extend the slide, and bring out the BBQ.
Hoppy220
scotthas wrote:
Go for it. I would make sure your level for the fridge if you have an rv fridge.
Somewhere I read where someone posted from the owners manual of, I believe, a norcold fridge, it stated 3 degrees side to side (as standing looking at the fridge), and 6degrees front to back. Have you guys ever done the math on that, it would almost be impossible to stay in the camper and be out of spec. Assuming the camper is 8' wide 6^ equates to 10" of side to side out of level. Let call 33' an average for camper length, 3^ in 33' comes out to 20" out of level. Would be mighty difficult to be comfortable in a camper that far out of level.
I know this is way off topic, just found that interesting when I actually figured how far out of level that was
rhagfo
There are big advantages to towing with the 5er level!
No need to disconnect no real need to run out slides if at rest stop, if campground sure easier to get around.
