Linoleun coming loose ????
ilvtravln
In a narrow space between the shower and bath cabinet the linoleum is lifting up slightly, any ideas as how to reattach it? Thanks
Art
6 REPLIES 6
ilvtravln
I can't get under it so maybe stapling it down and using some trim might work. Thanks
Art
rhagfo
We had the same issue, we came across it when buying the Copper Canyon the Linoleum edge along the step up to the bedroom area was curling up, that and a drawer track issue got us an additional $500 off the price.
I simply stapled down then put a $5 piece of oak trim. The drawer slide was a simple couple screws.
Dick_B
Would vinyl or rubber molding work for this problem?
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
JW_of_Opechee_S
Maybe a small decorative PVC trim piece glued and fastened.
Have Fiver will travel with little or no notice at all. I do need to stop at rest areas now and then:)
Dayle1
On many units, the vinyl flooring is not glued down to the subfloor. Just stapled along the outer edge before the exterior walls are installed. Then interior walls, cabinets, toilet, bathtub and furnace grills also secure it. If it is curling up, then someone cut it shorter than it should have been cut.
Larry Day
Texas Baptist Men-Retiree Builders since '01
'13 Silverado 3500HD LT 2wd CCSB SRW, custom RKI bed
'19 Starcraft Telluride 292RLS
Rig Photos
md_procouple
We had the same type problem... we re-secured it with double sided carpet tape.
Good Luck and Happy Camping
Vickie, Me, and "Scruffy" our dog make THREE
:W
