โSep-04-2019 06:53 PM
โJun-26-2020 08:59 PM
โSep-06-2019 07:46 PM
camper1013 wrote:
towingplanner.com has some great weight info. You can enter your weights and it will help calculate thing out for you.
My 5th wheel is 14k on the scale and just about 3k pin weight. There are a lot of people that pull mid sized 5th wheels with 3/4 trucks. We had to upgrade from a 1500 and went straight to the 3500.
โSep-06-2019 12:45 PM
โSep-05-2019 06:07 PM
โSep-05-2019 05:49 PM
Michelle.S wrote:
Your Wife, Kids, and Dogs aren't going Camping with you?? Since you're only adding your weight.
โSep-05-2019 05:41 PM
4x4ord wrote:usmc616 wrote:
Hi all, I currently tow a TT but am looking to get a fifth wheel. My questions are about "pin weight". My current TV is a 2004.5 Ram 2500 with the HO 5.9 Cummins rated to tow 13,050lbs. GCWR is 20,000lbs ( I found this on several tow guides), GVWR is 9,000lbs ( from label on door) and curb weight is 6727 lbs ( from same label on door) but weighed 7540 on scale( full tank of diesel, 140lb driver, cap on bed and tool box in bed) . My truck is a 4x4 with a 6' 3" bed.
With the above info I am trying to find out what will be my limiting factor when looking at fifth wheel campers. If I understand it correctly I should estimate 15-20% of the fifth wheel GVWR to be my pin weight, is that correct??Iif so then I only have 1490lbs available of pin weight? ( GVWR- Curb weight) is that correct? Educate me please
Many 3/4 ton owners ignore the GVWR of their truck and use the rear axle rating as their limiting value. If you where buying a truck to use for a fiver I'd say get a 1 ton SRW but because you've already got a truck I'll say ignore the GVWR and let your rear axle rating determine your maximum pin weight.
โSep-05-2019 05:38 PM
โSep-05-2019 05:34 PM
TXiceman wrote:
The limiting weight on your 2500 is the pin weight of the trailer and the trucks GVWR and GAWR for the rear axle. A typical 5er when loaded has a pin weight around 20% of the trailers GVWR.
Weigh your truck loaded for travel with passengers, cargo, hitch and fuel. now you have a baseline for selecting a trailer that will not over load the trucks ratings. Adding air bags and help springs does nothing toward increasing the trucks ratings.
Ken
โSep-05-2019 01:53 PM
Bob Shaw wrote:troubledwaters wrote:
You can tow a lot bigger TT than a fifth wheel and still stay within your ratings - Just Saying.
That's not what my owners manual says. My 5th wheel tow rating is higher than the tt tow rating.
โSep-05-2019 01:41 PM
โSep-05-2019 06:46 AM
โSep-05-2019 05:08 AM
valhalla360 wrote:
There should be a sticker on your door frame that gives the max payload and subtract off anything added since it came from the factory.
Actual scale weights are better but if you want to start selectively ignoring the ratings, you can do whatever you like but live with the results...it may be nothing but it's on you.
Generally 5ers assume 20-25% of the trailer as pin weight.
โSep-05-2019 04:15 AM
โSep-05-2019 03:14 AM
