Lp stove not percolating coffee
rtreptow7
We dry camp a lot with our fiver and make coffee on the stove top. The inside stove really wonโ€™t percolate the coffee. It barely bubbles up. The outside lp stove does, takes about 20 minutes. On the inside stove there seems to be very little adjustment in the flame. Seems the same between low all the way to just before high, then the flame gets taller. It is a nice blue flame and not flickering orange. Itโ€™s the same with all three burners. I normally make coffee outside anyway, but in the early spring and late fall we would like to do it inside the rig. Also, we can boil water in a pot on inside stove. Maybe itโ€™s the tall shape off the coffee pot that makes it difficult to percolate?
2018 GMC Sierra Denali 2500HD Crew Cab 6.0L 4.10
2019 KZ Durango 1500 286BHD fifth wheel
2010 GMC Sierra 2500HD Crew CAb 6.0L 3.73 REPLACED
2004 Chevy 2500HD Exteneded Cab 6.0L 4.10 gears REPLACED
2004 KZ Frontier 2453P-F fifth wheel-REPLACED
8 REPLIES 8
94-D2
Chances are the inside stove is a low pressure and outside is a higher pressure appliance. This results in lower and higher BTU output. Answer for inside Is a smaller percolator, or just heat it on the outside stove. This is normal for most RVโ€™s. Probably not a plug or restriction. If you have even flame inside, with proper even flame color, you burners are fine.
2018 Ram 3500 Crew Cab Laramie 6.7L, Aisin, air ride, Ram puck prep, SuperGlide 20K auto slide.
2018 Bighorn Traveler 4 slide w/Apt.
Itโ€™s not what youโ€™ve done that commands respect, itโ€™s what you do.
Happy Campinโ€™
TXiceman
cavie wrote:
the front center burner on must RV's is the hottest burner.
Not necessarily true. Our stove has the right rear as the largest and hottest burner. The other tow are smaller.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
cavie
2011 Keystone Sprinter 323BHS. Retired Master Electrician. Retired Building Inspector.
All Motor Homes are RV's. All RV's are not Motor Homes.
full_mosey
Examine the innards of the percolator and you will see a dome shape at the bottom of the riser that brings the water up to the grounds cup.
You must boil the water under the dome, not along the sides of the pot.
HTH;
John
jdc1
Does the stovetop burner have interchangeable orifices? If so, get a larger orifice. It will provide more propane to that burner. Most cooktops have one burner that does this.
RoyF
Sounds like a blockage somewhere in the line. Do you get good gas pressure to the furnace? If yes, do you get good flow to the oven? (I am assuming that you have low pressure.)
DownTheAvenue
Perhaps you have the flame too high. The hottest part of the flame is the blue tip. If the flame is bathing the sides of the coffee pot, then it is not hot enough at the base of the fire to boil water, and most of the heat is escaping up along the side of the pot. It may seem counter intuitive, but down the flame to a low setting and your coffee pot will percolate.
Likes_to_tow
Get yourself a drip coffee maker, boil the water and pour it in slowly. The problem is solved and the coffee tastes better than perked coffee!!
