Need help choosing a pure sine wave inverter
joanw2947
I am planning to replace my current modified sine wave inverter (Xantrex PRO XM1000 MSW). Xantrex has quit making the PROsine 1000 that I was considering. I am now looking at a COTEK ST1000-112 or a WFCO WF-5110H. Do you have any experience with these units or any information that would help me make a decision? Thanks.
16 REPLIES 16
Tequila
pianotuna wrote:
Hi,
You may wish to look at the cheaper Xantrex Prowatt line.
http://www.bestconverter.com/Prowatt-SW1000-Sine-Wave-Inverter_p_374.html#.VlkNcF7k-1t
$287 for the 1000 watt and $347.50 for the 2000 watt.
I'd go with the 2000 watt as the extra capacity means the inverter won't often be working hard.
Ok I used to be an electrician and I have to comment on this. First of all, inverters do not work hard. If they have the capacity, they can handle more draw on them. a 1000 watt inverter feeding a 200 watt draw is no less efficient than an 2000 watt inverter doing the same. The big thing is that the larger the invertor, the heavier the guage of wire you require to feed them from The Battery, and the closer to the battery it probably needs to be. I am sure there are plenty of do it yourself instalations out there that are a fire waiting to happen. A 2000 watt inverter requires a pretty heafty battery feed, something like #4 depending on how far away the battery is. Good idea ot load up your inverter with all the stuff you could conceivably run off it and feel that battery feed wire. If it's warm you have an issue.
joanw2947
Thanks for all of the information you have provided. It is so helpful to have concrete data to follow up on. I can hit the internet now and make a decision.
pianotuna
Nomad III
Nomad III
None of mine have been hard wired on the 120 volt side. Instead they have fed an outlet into which I plug in the shore power cord. This allows for maximum flexibility and means that when I come across an extra sensitive GFI outlet, I can by pass the inverter quickly and easily.
2oldman wrote:
All my inverters have been hard-wired.
Regards, Don
allen8106
Magnum MMS1012, because Handy Bob said so.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
2oldman
joanw2947 wrote:
Sorry. I forgot to include that the inverter has to be hard wired.
pianotuna
Nomad III
Nomad III
Hi,
So add a male plug to the "hard wire" and insert it into the output of the inverter.
Regards, Don
WNYBob
I have a Samlex SSW-2000-12A in my pickup, with a remote status/on off panel. Very satisfied. Site has many wiring diagrams, to help with instalation.
dahkota
bbaker2001 wrote:
best converter.com Randy will give good advice
I have a 350 watt. trying to figure why would one need 1000 or even 2000
all my lights are 12volt.
Our coffee pot takes 900W and various other appliances need 300 - 750W. So we have a 1200W.All our lights are also 12V.
2015 Jeep Willys Wrangler
2014 Fleetwood Bounder 33C
States camped: all but Hawaii
more than 1700 days on the road
12thgenusa
With a little ingenuity the ProWatt can be "hard wired". I used a standard three-prong plug with a short piece of 14-3 power cord to a j-box located close to the inverter. From there ran standard 14-3 Romex to the manual transfer switch located next to the power distribution panel.
2007 Tundra DC 4X4 5.7, Alcan custom rear springs, 2009 Cougar 245RKS, 370 watts ET solar, Victron BMV-712, Victron SmartSolar 100/30, 200AH LiP04 bank, ProWatt 2000.
bbaker2001
BB from California
2015 Ram 3500
2001 Cardinal
best friend is my wife ๐Ÿ™‚
joanw2947
time2roll
I have and recommend go power brand. Not exactly the low cost solution.
What ever you choose I also recommend separate components.
1000 always seems like an odd size. Usually suggest 300 or 2000. If 1000 is what you need then it is fine.
2oldman
I've run a Prosine (excellent),a Samlex (decent) and now running a Cotek 4kw inverter. It's only been in a couple weeks, but so far seems fine.
