Jul-17-2014 07:43 PM
Jul-21-2014 02:50 PM
bpounds wrote:Cummins12V98 wrote:
I don't recommend running on one tire but sitting while you work on the other tire won't hurt a darn thing unless the tires are junk.
I have to agree. Running load is one thing, static load is another. I guess there is risk in everything, but doing that doesn't worry me.
I got new tires installed this morning. This is how America's Tire lifted my trailer. Four floor jacks, four tires off. In/out in about 30 minutes, and on their busiest day. I had no concerns with any of their work.
Jul-21-2014 08:55 AM
Jul-20-2014 01:19 PM
Jul-20-2014 12:49 PM
danojeno wrote:travelnutz wrote:
Ya, but you saved money because you went to DISCOUNT TIRE and you are not happy??? Whoood a thunk it!
Not sure where OP is, but where I'm from, Discount/America's Tire is a great company. I have been a very satisfied customer for over 25 years. How has your experience been with the company?
Jul-20-2014 10:37 AM
Cummins12V98 wrote:
In the pic above the jack is in my opinion not in the correct location. The jack pad is sitting well inboard of the spring hanger. If they were to have positioned the jack parallel to the RV they could have been able to get under the spring.
Jul-20-2014 09:49 AM
Jul-20-2014 05:35 AM
Jul-19-2014 12:31 PM
Cummins12V98 wrote:JIMNLIN wrote:
There is no single jacking point on the frame on a trailer that will work on all trailers because of several reasons that I'm familiar with
Trailers weight
trailer length
trailers frame type
trailers suspension type
and other factors.
Laknox make a good point on the tire that is flat is still carry most of it load. I've ran tires flat at nite on my equipment trailers when on long trips to the next jobsite. Never noticed a flat till the steel wheel started rolling on the pavement and created a beautiful spark show. Other tire(s) on that side were either fine or cut by the slinging steel belts.
Having split a tread belt a 16.5" 12 ply tire with the ramp trick even after my trailer mfg and tire dealer warned me not too I wouldn't advise anyone to let a single tire hold up twice its rated load rating for any length of time. Remember tire damage is cumulative.
I guess you should never go over a curb and allow one tire to hang as you move until it again makes ground contact.
I use a TrailerAid Plus to do maintenance and road side repairs with no ill effects because I run quality tires.
Jul-19-2014 11:23 AM
Jul-19-2014 08:42 AM
Trailers weight
trailer length
trailers frame type
and other factors.
Jul-19-2014 06:34 AM
Jul-18-2014 01:08 PM
bpounds wrote:laknox wrote:
To pick nits, a lot of people here will argue that using a ramp to lift the trailer high enough to change a tire, will overload the good tire, thus damaging it. On an ST, I might well believe it; an LT, not so much. 😉
Lyle
LOL, some people would.
To which I would ask, how does that damage the good tire more than it was damaged during whatever driving was necessary to pull off the road and fix the flat?
Jul-18-2014 12:58 PM
bpounds wrote:lots2seeinmyrv wrote:
...Picture for everyone would be great!
This is how I lifted mine last weekend to service the axles. The jack cup is under one U-bolt. Lifting under both would be better, but my jack base is a little too wide. Lifting here does no harm.
Jul-18-2014 12:54 PM
Lyle
