Onan dies in the Heat
toytacoma8
Never had any problems with the Microquiet 4000 in our 2006 Victory Lane til last weekend. We were camping and it was about 95 degrees and 4000 feet. Gen ran for the first time about 35 minutes and stumbled and died. Would restart for a few seconds and then not start at all. after an hour or so it would run again but only for about 10 minutes. Did this several times.
In the morning and evening when it was a little cooler it seemed to stay running.
I am guessing vapor lock from what I have read but I have not seen any definitive answers on how to cure it. Add a fan? open up an air duct?
Any ideas?
18 REPLIES 18
dirtyhandz
I have experienced this twice. First time with my 28 foot Weekend Warrior. Same generator as yours. When it got hot out that thing would just over heat just like yours is. I just sat a small small fan under it blowing up and never had another problem. Ran hundreds of hours like that in 90+ heat. On my 36V Jayco Recon it was fuel pumps. The Onan pump would overheat and die. After the second one I went to Auto Zone and bought a $30.00 electric pump and placed it back at the fuel tank where it should be. Electric pumps push fuel great, but really cant pull fuel and over heat. I used a 3 to 4 PSI pump. If you do this just check and see what psi the pump in your genny runs at. Some Onans are 2, some are 4. Mine has been running hundreds of trouble free hours like this.
Vulcanmars
Bedlam wrote:
Vulcanmars wrote:
If it's gas (not LPG) most have an adjustment for higher elevation on the carb. High elevation = lean fuel mix= runs hotter.
If it continues to die you may have a fuel pump going south.
Higher elevations result in a rich burn if jetted for sea level due to less air available. I have noticed more smell from the exhaust on my gasoline 5500 and LPG 2500 at elevation but never had plug fouling to worry about rejetting.
Duh, thanks had a senior moment.
Mars
04 V10 F250 SDCC 4X4
2016 Wildwood 32BHDS
allcool
Dwight45 wrote:
The fault code is 36. Again this is a brand new unit. Plenty of gas in the tank. Runs fine with the compartment door open. Not at high altitude.
Thanks
Sounds like heat is your problem. I also thought at 1 point it was mine also. In PHX on 115ยฐ days running my gen and burnt myself trying to flip the breaker switch in the genny compartment... It does run hot when its hot out. Air cooled motors are like that. As far as I know, there is no engine shut down or fault code for overheat on the Onan HGJAB(iirr) carb 5000 series.
So if it does stop from overheat, was told by an old timer Onan genny dealer in Phx, that when they get really really hot from blocked air flow the oil starts to boil/foam and that shuts it down on oil switch. But you did not have a oil fault code, so it might be hot seizing up..? Hopefully not.
offtohavasu wrote:
Make sure it's vented properly under the coach.
Agree with offtohavasu, Thats is what I'd check also...
Should be an area underneath the genny that sucks air in, and another that blows out hot air. Make sure the air inlet and outlet openings
in the bottom of the genset are not restricted in any way. Without the genny cover on the fan won't circulate air thru the genny correctly, but it will run like that.
Here is the troubleshooting guide from the manual for fault code 36, it is a generic code that says without fault condition.So that does help cut down on the possible problems.
GENSET STOPPED WITHOUT FAULT CONDITION โ€“ FAULT CODE 36
Logic: RPM less than 500 and Sense Voltage S1โ€“S2 at 0 VAC when no other fault condition occurred
Possible Causes: Auto Gen Start (AGS), fuel supply, air fuel mixture, exhaust system, loads, Inverter/Charger,
choke, demand regulator, carburetor, generator drive system, generator windings, ignition, wire connections
Diagnosis & Repair:
1. Verify that Last Fault is FC 36: Yes, continue diagnosis; No, troubleshoot actual last fault.
2. Verify whether AGS stopped genset: Yes, disable AGS or explain AGS function to customer (see
PSB-666); No, continue diagnosis.
3. Verify engine rotation manually: repair engine damage as necessary.
4. Disconnect genset control P1 connector, verify P1 pins are fully inserted and inspect pin condition per
PSBโ€“676: insert, repair or replace pins as necessary.
5. Reconnect P1 connector and test run genset for fault occurrence: repair or replace pins in connector as
necessary.
6. Check air filter cleanliness; replace air filter as necessary.
7. Check for blocked or damaged exhaust system: repair or replace exhaust components as necessary.
8. Measure AC current while running genset with vehicle loads: identify faulty or short cycling loads.
9. Determine battery charge rate (typical default is 80 percent): if adjustable reduce to 30 percent.
10. Measure genset load capability with shop load bank.
11. HGJAD only โ€“ Run genset in Engine Run Only and externally excite field F1โ€“F2 with 12 VDC or 24 VDC
and measure main and quadrature winding AC output.
12. Non EFI โ€“ Verify genset operation and outputs with Break-Out Tool 420โ€“0603 and Instruction Sheet
R1098.
13. Measure AC frequency while changing engine rpm to determine if frequency response matches engine
rpm response: repair damaged generator drive system as necessary.
2007 WW FSW3200
RZRS k&t Turbo
2 LT500
1 Lt500 hybrid
F350 CC 6.7PS Platinum
Bedlam
Moderator
Moderator
Since this is a new unit, take it back to the dealer for resolution. You do not want to make changes that may be used against you to void your warranty. My 5500 ran for hundreds of hours without issue and yours should too.
offtohavasu
Dwight45
Forgot to say that it's so hot in the compartment that you can hardly touch anything. I propped the compartment door open and ran it all night for AC. No problem.
Dwight
Dwight45
Thanks
Dwight
allcool
Dwight45 wrote:
I'm having this problem with a brand new 5500 onan. If I prop open the generator compartment door it runs fine. Close the door and it overheats. Still think it's the fuel pump?
Dwight
Go in your Onan manual and look to the section that completely explains trouble codes. Go to your TH and check what trouble code yours has stored.
If you haven't got it figured out by then, come back here and tell us what trouble code(S)you got.
Until you do this, everything is just a wild guess.....
2007 WW FSW3200
RZRS k&t Turbo
2 LT500
1 Lt500 hybrid
Dwight45
Dwight
Bedlam
Moderator
Moderator
I agree that a weak/failing fuel pump would cause issues when ambient temperatures are high. Altitude should not effect the pump, but a partially clogged fuel filter or fuel tank vent will make a pump work harder than it should.
GL
Fuel pump.
I have an Onan 5500, had an identical problem. Whenever it was hot enough, it would just quit. After it cooled down for a time, I could get it to start back up. On that trip I ended up pointing a small portable fan up at the bottom of the genny (right where the fuel pump is), and it stayed on long enough to get me through that trip.
I replaced the fuel pump when I got home and haven't had the problem since.
2005 Chevy Silverado 3500 4x4 D/A (LLY) Dually Crew Cab
2007 Jayco Recon F36V
Dirtclods
Make sure your frig is on gas the auto does not always trip on it own if its running on gas not propane. 2nd that on the fuel I always run the higher octane as well.
AAA Motorcycle RV Plus
TyroneandGladys
Have had problems with 85 octane fuel with generator do not know what you filled with
Tyrone & Gladys
27' 1986 Coachmen
Y-Guy
Moderator
Moderator
You've been given some good advice. I will say from the fuel pump issues I had with my 5500 I'm not sure that's the issue or not. It's very odd that it's having issues while hot which makes me think it's more related to your altitude setting. But few other things. While looking at the generator itself you can look at the switch for the number of blinks, and get the fault code. Knowing that can really help. I'd also check your oil to make sure it's not dirty as well as your air filter.
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
