Pantry Door / Drawers
Memphisdoug
We just purchased a used Crossroads Paradise Pointe. It has a pantry door with the slide out drawers inside the pantry. We are having a problem with the 3 drawers pushing the pantry door open and sliding back and forth as we travel. There doesn't appear to be any sort of locks for the drawer slides and the roller latches on the door aren't enough to keep it closed with the drawers pushing on it. Any ideas on how to keep the drawers stationary?
2006 Silverado 3500 Crew Cab
2006 Crossroads Paradise Pointe 36RL
13 REPLIES 13
robrose1
I bought the child proof locks that slip thru the door handles. Solved our problems of doors opening.
Rob and Rose
2013 Winnebago Lite Five 29FWRLS
2006 GMC DURAMAX/ALLISON
Cummins12V98
Mile High wrote:
We installed these from Home Depot on ours a couple of years ago and they work perfect:
You can get them to match your other hardware - surface bolt Stanley. Just make sure the throw is long enough, as there are several different brands and type.
Nice job, looks OE!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
gitane59
This is also exactly the solution I used on our new unit as well. Drawers would slide open with any weight in them pushing the outer door open all the time hitting the woodwork.
Thank MileHigh for saving me the work to post the pic.;)
2014 Landmark Savannah, Mor-Ryde IS with Dexter disc brakes, 17.5 wheels with Sumitomo skins,
2010 Ford F350 Lariat CC LB DRW 6.4L Diesel, Firestone Ride Rite Airbags
Mile_High
Thanks!
It was kind of a necessity on these big 8 drawer pantries. Folks were having problems with them hitting the pantry door hard enough in travel that it would actually break the door at the hinges, especially the drawers loaded with canned goods and pots and pans. One of the other owners on our owner forum gave us the idea.
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
Onespeed405
That's a great idea Mile High.
If I had (or in the future) drawers within the cabinets, I will use this.
I was only trying to solve the problem of doors popping open and throwing our dishes around.
2005 Chev 3500 Duramax/Allison Ext Cab SRW 4x4 Long Box
Blue Ox Bedsaver, Hawkshead TPMS, Rear View Camera System
2007 Citation Supreme 31CKDS
220 W solar, 2800 W Magnasine pure sinewave inverter/charger/battery monitor, 4x6 volt deep cycle, Rotochoks
Memphisdoug
Those look like the perfect solution Mile High
Mile_High
bluka43
View a post by me, bluka43 on 3/2/14 about this very same thing and what I did to remedy the situation easily and for good.
Allworth
A screen door hook and eye?
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
klassic
All the drawers in my unit have clasps like this on the bottom to hold them closed.
klassic
2016 Jayco North Point 341RLTS
2017 F350 Platinum
Reese Signature Series 18K slider
520watts solar
Onespeed405
Here is a solution I came up with ... Works Fantastic !!!
Hope this helps.
wallaceb
Try carefully looking the structure over --- there should be some kind of locking device usually about 1/3 the way up.
laknox
Personally, I would put some padding on the inside of the pantry door, to cushion the drawers, then put a latch on the outside of the door to keep it closed.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
