โAug-13-2016 07:33 AM
โApr-07-2017 06:00 AM
โApr-06-2017 06:33 AM
RainbowsEnd wrote:
Current information as of this posting from a phone call to Pullrite Superglide for the 16K with the latest design of the plastic wear plate, part #2700, use WD40 or 3 in 1 only. NO graphite or silicone used.
"Do not use any lubrication other than a light oil on the Way Tubes of your SuperGlide hitch. Using other lubricants, such as those with a silicone base, will create a residue and may hinder the functionality of the Turntable Cam Arm Assembly. Buildup of old oil and dirt can also create a residue over time and needs to be kept clean." Read more on their owner manuals online.
โApr-05-2017 09:06 AM
โAug-21-2016 01:09 AM
Colo Native wrote:
I have a 18K super glide and the book says to spray WD40 for lube but as we all know it is not a lube the factory said use it, BUT in Trailer life a month or so ago it mentioned using silicone which is a lube. Anybody using silicone? Or what other choice than WD 40. It is messy and I am tired of getting all over everything even though I wipe it off the hitch regularly
โAug-20-2016 09:40 PM
โAug-20-2016 09:28 PM
โAug-20-2016 04:31 PM
โAug-14-2016 09:19 AM
โAug-14-2016 09:03 AM
I would 100% follow exactly what Pullrite says. I say that from a bad experience with them. Back in 2005-06 I had a hitch like yours, used the recommended silicone. Ended up with some major galling and head seperation.
โAug-14-2016 08:37 AM
โAug-14-2016 08:03 AM
Coach-man wrote:I use Slip Plate on mine ( bought from Pullrite ) on the face of my hitch. Although it does not twist and turn it makes it much smoother to back under and pull out from the trailer.C.B. wrote:
Before using silicone, call factory back and see if using Slip Plate would be ok.
C.B.
?? Not sure what "slip plate" is, but with the super glide hitch the contact surfaces do not move, and no "lubercant should be used". Any lubercant ing should be done down below where the hitch turns and moves, perhaps also on the jaw mechanism.
โAug-14-2016 06:28 AM
C.B.
โAug-13-2016 02:28 PM
โAug-13-2016 09:57 AM
