Dec-26-2016 11:07 AM
Apr-03-2017 08:19 AM
Apr-01-2017 04:48 PM
Mar-30-2017 09:10 PM
kofire wrote:
Looks fairly normal to me for a three axle trailer. The rear tires take a serious beating. Also how much weight are you putting in the trailer? Those axles are gonna have an upward bend in them that levels with a load. Obviously there could be something else wrong but all of my triple axles have prematurely work the rear tires.
Mar-30-2017 11:09 AM
Mar-30-2017 04:03 AM
Mar-30-2017 03:03 AM
Jan-02-2017 04:01 AM
tinner12002 wrote:Mmaxed wrote:
My tandem axle was doing this when the hangers and bushings were getting worn.
Good idea!! When I checked my 06 the plastic bushings were almost non-existing so that would definitely be a place to start, even installing a wet bolt kit while you have it apart.
Jan-02-2017 03:59 AM
Dec-27-2016 11:45 AM
Dec-27-2016 11:23 AM
Dec-27-2016 08:42 AM
fj12ryder wrote:
Were these tires new before you put them on the trailer? If not, could the wear have something to do with changing them from one trailer to the new one? Changing sides perhaps.
Did you inspect the tires that came off the trailer when you bought it? If the axle is bent perhaps it happened before you took possession of it and the old tires were affected but you didn't notice it at that point.
As for tire scrub, do you have a sharp turn that you have to make very frequently? Seems unlikely but you never know.
Dec-27-2016 08:32 AM
MWJones wrote:
Everyone will tell you it is a bent axle, even the manufacture will.
But I say from experience - maybe NOT.
I had a tire do that on outside enough that it was SLICK on outside.
Put on new tire and never wore uneven again!!!! Just saying......
Dec-27-2016 08:07 AM
Dec-27-2016 06:54 AM
tinner12002 wrote:
I'd say with that mileage I'd put on a new set of 4 and travel on!
