Refrigerator
donajohn
I unhooked my battery to have it tested, and my refrigerator turned off. Controls went dark. Reconnected battery and manually switched refer to Gas, then unhooked again. Don't know if it ran on gas while I was away for an hour or not. I thought refer would still run on AC from the shore power even if Battery not working.
Guess I'm wrong?
7 REPLIES 7
newman_fulltime
Dude just buy a new converter and fix the problem
Old-Biscuit
Your converter is the issue.......which is in your other post about your converter
AC Shore Power>>>>>>Converter>>>>>>>DC Voltage ----minimum of 13.2V DC Out with battery POS cable not connected
wrgrs50s
In some cases the converter will supply the needed voltage to keep 12v appliances working. If your battery is low due to the converter not charging it, you may have a converter issue.
If you've had your battery disconnected for any reason previously and accidently arced it or temporarily hooked it up with the cables on the wrong posts, you could have blown the fuses on the back of the converter.
Walter and Janie Rogers
2012 Sundance 277RL
TV 2006 Silverado 2500 6.0
SidecarFlip
12 volts powers the electronics and propane ignition... must have
110 volts powers the Cal Rod heater in the boiler
No 12 volt power source, no work.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
donajohn
Got it. Thanks, guys.
enblethen
Refer would need to be in "auto" plus the converter must be powered to supply 12 volts DC for the control. Display should have remained lit if you had power from the converter.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
donn0128
Nope! Refers need 12VDC for control voltage and spark for the igniter.
