Removing heavy hitch from truck
Durb
This has worked well for me so I thought I would share. I leave my hitch hooked to the 5er, remove the rail pins and use the landing gear to lift the hitch out of the truck. I use a 500# hydraulic table from Harbor Freight ($136) which happens to fit the hitch perfectly. I jack the table until the entire weight is off the kingpin then unhook the hitch. Lower the table to ankle height and roll into the garage. No lifting, no climbing.
20 REPLIES 20
gtnsmlr
I got a 99 dollar lift from Harbor Freight, I took a little extra fabrication to toughen up the mounting but it makes short work of the hitch and the 300lb generator.
The older we get, the faster we go
Durb
To bucky,
The hitch weighs 300 pounds. It would take bigger guys than me, probably four, to manhandle it out of the truck. The vertical corner brackets have a lower hole and is where the hitch is pinned to the bed rails. The rear aluminum channel with the eye screw pivots back so I don't have to crawl into the truck to hook up the breakaway cable. I do like a neat garage, my office is a mess!
Mile_High
Those tables are awesome. I bought one from Harbor Freight, used it to install my 300 lb Onan generator, then sold it for almost the same price on Ebay.
PS - nice looking garage by the way.
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
laknox
I =did= do a "kingpin hoist" one time, when my brother borrowed my FW and his '05 F350 cr@pped out. Just loosened the u-bolts on the Companion, lifted it out of the Turnover Ball base, pulled his truck out from underneath and slipped my truck back underneath. Dropped the front of the FW back into my bed, took the weight off, unhooked it from the king pin and slid it into =my= Turnover Ball base and tightened everything back down. Away I went. 🙂
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
starcraft69
I leave mine attached to the kingpin. Easy peasy !!!!!
2007 chevy 2500 HD 6.0 longbed
2015 Eagle HT 28.5 5th wheel
tucker the fishing dog
ramgunner
You can also get a hitch-mounted crane to assist. I found one that comes in two pieces that works well for this.
http://www.ramgunner.com/stark_crane.html
Editor - http://www.RamGunner.com / http://www.MomentumGunner.com
2014 Ram 3500 Tradesman/CTD/AISIN/4.10/4WD/CC/LB/DRW/VHF/UHF/APRS/CB/SCANNER
Grand Design Momentum 385TH (Polaris RZR800/VHF/UHF/HF)
CWSWine
Get on the cell phone and call my grandsons to come lift it out. Simple and safe....
2017 Discovery XLE 40 D DP
Sold Grand Design Solitude 310GK-R
Sold 2016 GMC Denali 1 ton Diesel 3722 CC
5er 13,600 - 3100 pin - Truck Weight 11380 Truck GVWR 11,500
Only 180 lbs below my trucks MAX GVWR
Me_Again
[IMG]http://i269.photobucket.com/albums/jj53/snoking1127/IMG_20151012_081603969_zpsildax7s2.jpg" wid...
Moderator edit to re-size picture to forum recommended limit of 640px maximum width.
bucky
That hitch looks like a very heavy beast. Nothing wrong with using brains instead of your back to accomplish a goal. To each his/her own.
What are the vertical silver brackets at each corner of the hitch. Did you install them to keep the hitch from coming off of the table or do they serve some other purpose?
Puma 30RKSS
stro1965
Njmurvin wrote:
I do something similar. I back the truck into my garage. My Harbor Freight electric hoist is mounted in the garage rafters. I pull the pins on the Superglide, strategically place chain hooks on the hitch and lift it off. Then I drive the truck out from under it and roll my metal utility cart under the hitch and lower it onto the cart. The whole process takes 15-20 minutes.
Exactly what I do. Right down to the Harbor Freight winch. Works slick!
2018 Ram DRW 3500 6.7
2019 Keystone Alpine 3021
allimax
Maybe my hitch isn't as heavy as most. I take it out in 2 parts and it is still manageable. I'm not a big guy either (5'8", 170). That Trailer Saver does look like a beast, though.
2010 Montana 3455SA
Mor/Ride kingpin, wet bolts, Progressive Ind. HW-50C EMS,TST 507RV TPMS, GY G614's
'07.5 Silverado D/A LMM 3500HD
Extended Cab DRW 4x4 LTZ
Bilstein, Reese R20, Banks Economind tuner, Speedbrake, RamAir, Monster exhaust
Memphisdoug
I use my skid steer and forks. Piece of cake to remove!
2006 Silverado 3500 Crew Cab
2006 Crossroads Paradise Pointe 36RL
gmcsmoke
block and tackle and a furniture dolly.
Campinfan
Crodad wrote:
I just leave the hitch attached to the kingpin.
I did the same thing but it was a pain to line the hitch back up to the rails when I needed to reinstall it. Of course, I was by myself.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
