Replacing Tires
Trixie47
Tired of all the blowouts we have had on the 5er. Originals ST235/80/r16 E. I see lots of controversy on the ST tires. What is the most people are using to replace tires with ? I am looking at Bridgestone Duravis R250's LT235/85/r16 E. Would these interchange with what I now have on my 5er? Avalanche 330RE 11,710 pounds. I am getting really confused and with all the knowledge on this forum figured someone would be able to help me out....Thanks :?
2008 Chevrolet Silverado Crew Cab DW
2012 Keystone Avalanche...4 Slides
21 REPLIES 21
NC_Hauler
IF 6,000# axles and OEM tire is "E" rated, the Duravis250 or 500 has been highly recommended and I would also recommend the Michelin XPS RIBS also, though they are pricier.
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
SH
Here are a couple of tire threads you may want to read.
Tires 1
Tires 2
Tires 3
Tires 4
Tires 5
2001 Alpenlite 35RK
2007.5 Chev LMM Duramax/Allison
BD Variable Vane Turbo Brake
TST 507
2010 FLHTC Electra Glide Classic Red Hot Sunglo 🙂
Dennis_M_M
Another vote for Michelin XPS Ribs. Run 8 of them (LT 235/85 R 16) on our 20k fiver - 2 axle duals.
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'13 smart CityFlame on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
crickeydog
Been running Michelin Rib tires on all of our trucks and 5'er for the past 10 years. Have never had a blow out.
Happy camping!!! See y'all down the road!!!:)
USAF RETIRED 02/1992
DOD RETIRED 04/2014
D/W US GOV/DOJ/DEA RETIRED 10/2010
PULL DOG:
2006 GMC 3500 CC DRW D/A LBZ 4X4 SLT
2004 HOLIDAY RAMBLER PRESIDENTIAL 30' SCD 5'ER
B_O__Plenty
Jayco-noslide wrote:
Frequent blow-outs aren't normal. Either overloaded, not enough tire, pressure too low or high or tires too old/worn.
Or poor quality original equipment ST chinese made tires. The Duravis would be one of the top choices if it was my trailer..
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
Jayco-noslide
Jayco-noslide
Allworth
With that weight, any Load Range E Light Truck tire will do. I run B. F. Goodrich Commercial TA (which have a good trailer tread pattern) in size LT 245/75R16 that is 1/2 inch wider and the same diameter as the original STs.
I got mine at Tire KIngdom at Semoran/Lake Margaret for about $700 for the four; mounted, balanced, and on the trailer.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
