Sailun Tire update
momentum_rv
Getting ready to start to begin to commence to think about my next set of tires for the TH 5er.
Have been looking at the Sailun S637. They fit the bill for size & weight needs and have good reviews so far.
So my very specific question is: Have any of you Sailun tire OWNERS had ANY regrets?
(lets try not to start a tire argument cuz they always go bad, and yes, I have read plenty about other tires just want to know about these at this time)
Thanks!
2015 Grand Design Momentum 385TH
2015 Ford F-350 DRW 4x4 Lariat
23 REPLIES 23
garysol
We will be there May6th weekend for opening weekend and again on September 23rd weekend for Halloweekends. Maybe we will see you there!
2020 GMC Canyon
2022 NoBo 19.2
blofgren
I think all of the 16" Sailuns have the ST designation now; mine from last year do. If memory serves me correct it had something to do with avoiding additional import costs that LT tires are subjected to or something like that. I don't believe the tire changed, just the labeling.
I also believe mine are rated for 4,180 lbs each. I do not believe that they have the 65 mph speed limit.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
2008 Corsair Excella Platinum 34.5 CKTS fifth wheel with winter package & disc brakes
fj12ryder
The ones listed in the link provided are actually ST tires, whereas the ones I ordered a couple years back were LT tires, but marked "For Trailer Service Only". And mine were rated at 3750 lbs. So those look like good tires, and their height is an inch or so shorter overall than mine. But a little more expensive. Give with one hand and take away with the other. 🙂
I imagine they don't have the normal 65 mph ST speed rating, but it didn't list it. Seems very unlikely though.
Howard and Peggy
"Don't Panic"
momentum_rv
Thanks, good to know... too late this time though.
Lantley
momentum rv wrote:
The 235/80-16 exists but I haven't been able to find them in the US only Canada. Maybe soon they will show up. I will probably just go with the 85s.
I have been told that these guys have the 80's series Sailun's
Trailer Tires and Whhels
alexleblanc
Paul Clancy wrote:
I am considering the Sailuns in the new size 235 80 16. My 5th has E tires currently and no clearance for LT(or st) 85s. Weight is ~10,500 with 11,500 gvwr. Wheels have 110psi rating. I am also considering the maaxis E. Reliabilty and longevity is the goal. Wondering how folks here would go. Sailuns and Maaxis are hard to get here but we mostly travel in the US.
Thanks All
Paul
Have you considered going to 215/85r16 LT,s instead? I don't think you rig is heavy enough to warrant a G rated tire. That size is the same height as the 235/80r16 you currently have.
TV - 2017 F350 CCSB SRW Platinum 6.7 + 5er - 2021 Grand Design Reflection 311 BHS + B&W Companion
On Order - 2022 F350 CCSB SRW Platinum 6.7
MartyMoose
Have had mine for just the second half of the season (after 4 blowouts on one trip - TOWMAX), You will be very impressed when you get these. Very serious tires. 62-63 lbs ea.
2014 Heartland 305RW Road Warrior
2012 Ford F250 Lariat
momentum_rv
I ordered 7. Will get them mounted up in the next couple of weeks. We'll see how they do.
Thanks all for the info!
garysol
No issues here with ours after a couple of seasons....
2020 GMC Canyon
2022 NoBo 19.2
justafordguy
1 year on Sailun S637s so far and not a single problem. Very heavy duty tires for sure.
2015 Heartland Gateway 3650BH
2017 F350 CCLB KR FX4
2005 F250 CC FX4
77 Bronco, 302,C4,PS,PB,A/C,33" KM2s,D44/Lock-Right,9"/Grizzly locker
Jerry_B
Three years with the 637 sailuns on my Mobile suites. I wouldn't have anything else.
Jerry B
Mobile Suites 36TK3
fj12ryder
Ah, I see. Thanks for the heads-up.
Howard and Peggy
"Don't Panic"
momentum_rv
fj12ryder
Have you seen the Sailun tire in a 235/80-16? I couldn't find a listing for that size with the Sailun. And just because it is the same spec as what you currently have doesn't mean it would be the same size. There are size differences between 235/85-16 tires as well.
Howard and Peggy
"Don't Panic"
