Sewer
SBrooks72
Hey all, I am on assignment in Louisville, Ky. My sewer line is frozen. Artic package my A**. Question: will antifreeze bust thru the ice and free it up? A fellow Rv'er on this and dear friend said salt would be worth a try but locals say it will ruin my holding tabks.
TIA,
Brooks
16 REPLIES 16
2oldman
ECones wrote:
jfkmk wrote:
2oldman wrote:
No, but a well-placed hair dryer might 'unthaw' it.
Seems to me it's "unthawed" right now.
Nicely played ... LOL
Yes.
SolidAxleDurang
When camping in freezing conditions, no tank valve (gray or black) should be left open. Only open the valve when the tank is full and ready to dump. Then ensure slickly hose is fully emptied (pickup to drain if necessary); then close valves again.
TV = 15 Ram 3500 Dually 6.7 / CC-LB / CTD / Aisin / 3.42 / 4wd / EBrake
5er = 12 Keystone Avalanche 330RE
Toys = 08 Kawasaki Brutie Force 650i 4x4 ( x2 ๐Ÿ™‚ ) 14 Arctic Cat Wildcat 1000
ECones
beemerphile1
Exactly where is it frozen? Are you using the furnace or electric heaters?
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Y-Guy
Moderator
Moderator
Brooks look around, check inside your kitchen cabinets see if there is an opening, probably at the back, that leads to the underside of the RV. Might be able to use a fan to force some warmer air down there during the day.
Where are your tanks located? Under the garage portion?
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
Old-Biscuit
Sounds like somebody is leaving waste tank drain valve open....otherwise why would it freeze ????
Are you sure freezing is issue OR cable pull has separated from valve??
Strabo
Just a thought but it may be clogged from toilet paper and not frozen.
04' F350 PSD TB SC FX4 XLT, TH-04' 32' Sandpiper Sport Fifthwheel WB Dual Axle
07' Rhino 686 SS106-ITP-AFE-BRP-T4-CDI-KIBBLEBWHITE-CVT-TSTICH-Ridgid LED LightBar-HID Conversion Kit-LIVEWIRE
04' Honda 250 Sportstrac quad
05' Honda 400 Ranchers quad
DutchmenSport
Just curious? Are you staying at the KOA in Clarksville, Indiana? I talked to the manager there about their winter workers that stay there and how they protect their campers from freezing and such. Good people there, the management. Let them know what happened. They may lend you an extra hair dryer or two.
jfkmk
Houston_Remodel
Start with the hottest water you can pour down the tank, and lots of it. The more thermal energy you add the better. While the hot water is doing its magic from the inside, the hair dryer is working from the outside.
Good luck. Let us know how it turns out.
2015 Starcraft Launch 24RLS
2014 Ram 2500 diesel 4x4
Guarded by 2 Jack Russells
SBrooks72
Yes, valves and tanks are enclosed. Pretty much screwed til weather is above freezing.
coolbreeze01
Really nothing for salt to harm, the valves are stainless, but I would try a $10 heat gun first. Mine from Harbor Freight really throws out the heat. Good luck.
2014 Sandsport 26FBSL
Oasisbob
Salt is a corosive and hard on your sever valves. As previously suggested a har dryer mcht do it. Then figure out why it froze. Need more slope?
Oasis Bob
Wonderful wife 3 of 4 kids at home. 1 proudly serving in USAF
2018 Ford Explorer
2001 Bantam Trail Lite B-19
HAPPY TRAILS:)
Y-Guy
Moderator
Moderator
Brooks I've read about using about 3 gallons of RV antifreeze, one guy said try to get it warm before you dump it in. Recall saying dump 1/2 gallon down the kitchen, bathroom and shower, follow by 1/2 gallon of boiling water down each of the drain followed by another 1/2 gallon of antifreeze. Other say use a couple boxes of table salt and hot water.
Are your tanks enclosed at all or totally exposed? Are you running the propane heat? Might keep the fan on and the cabinets open to air circulates.
