Should I tow this? ?
rbos57
I have a 2015 Ram 2500 6.4 Hemi 4.10 gear ratio truck
Max payload is 3280
All the charts say it's Towing capabilities of 15600 pounds.
What do you all think about towing approximately 13000 pound fifth wheel with this truck.Pin weight is 2250. And I do want to be able to stop it as well
29 ft tt
2016 RAM 3500 6.7 CUMMINS
26 REPLIES 26
Bipeflier
That is a little lighter than I pull with my Duramax.
Never been an issue and don't buy into the 6MPG BS.
You should be fine, just beware of taking everything you own with you.
2010 Cruiser CF30SK Patriot
2016 3500 Duramax
1950 Right Hand Seat GPS (she tells me where to go)
Greentreena
You'll be just fine in my opinion. You probably won't race up any hills or get stellar fuel economy but who cares - you're camping.
2008 Dodge Ram 3500 6.7 Mega Cab 4x4 SRW Laramie - Big & Black
Full delete, Torque Technolgies programmer, Sinister EGR delete
Hijacker Auto Slide/ P3
2006 Triple E Topaz 310RBXL
Wife, 2 kids (Murphy the dog - RIP friend)
Bionic_Man
I've never seen a 2500 come from the factory with less than a E rated tire. Sometimes people go up in tire size and end up with a D rated tire, but going up in size brings up the load capacity as well.
It won't hurt to check, but I would give 10-1 odds that it isn't an issue.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
Coach-man
Me Again wrote:
Coach-man wrote:
Finally, what tires do you have and what are they rated for? If stock truck they may be your weak link!
It is a 2500, so tires are fine. Chris
Oh really, just because it is a 2500, means the tires are fine? What rating are on those tires, the OP or someone could have replaced them at some point. Not all ยพ ton trucks come from the factory with the same tires, Tires, and wheels have options when ordering. Tire ratings are sometimes overlooked when calculating what can be towed. And since it appears the OP's TV will be at or a little above the capacity tires could be something to be checked!
AirBiscuit
I don't post often but geez. Diesel this and diesel that, blah blah...
A diesel in many instances doesn't instantly add up to much much more payload/capability. And for many people such as myself, a diesel just isn't a viable option. For instance, my truck is also my daily driver and I live about 8 miles from work and tow about 6-7 times a year, once maybe twice I tow 200 miles but most of the time I'm only towing around 30 miles on flat road. I have a 2015 Silverado 2500HD gasser with just slightly less payload than the OP.
11,000 lbs.? Are you kidding? I'd be just fine towing that! Up the steeper grades my rpm's will run up but who cares? That's what it's designed to do. How often are we all climbing mountains around here anyway?
Many more things come into play to decide if a diesel is worth it to people. As long as your within your capabilities, have at it for Pete's sake.
rhagfo
TopSlink wrote:
in 08 I purchased a chev 2500 hd 7.0 vortex all the manufacturers lit said i could tow an 06 raptor around 15500 i picked it up in Tenn. by the time i got it to Joplin, i stopped at the dodge dealer and traded it off for a diesel 1st long hill that truck saw on the way home i had my foot through the floor board and was doing a whole 15 mph it was down right embarrassing buy a diesel
OP is not looking at 15,500#!
He is looking at about 11 000#, that engine is better than the old 7L so likely will be fine.
TopSlink
spud1957
rbos57 wrote:
Montana High Country 293RK
9600 dry
You'll be fine. Mine is 9500 dry and I tow with a 6.2L Ford and love it.
2018 F350 6.7 4x4 CCSB
2022 GD Reflection 337 RLS
rhagfo
Once again the Weight Police are at it again!!!
The OP can carry that 5er with ease!!! He should also be able to pull it just fine with the 6.4 Hemi. The OP's Payload si 3,148 from the yellow sticker
Specs on the 5er;
Technical Specifications:
Length 32'-11"
Dry Weight 9,560#
Payload Capacity 2,915#
GVWR 12,475#
Hitch Weight Dry 2,075#
Hitch Weight Wet 2,495# 20 percent of 12,475
3,148 - 2,495 = leaves 653# for passengers and stuff, at the trailers max GVWR. So if the OP tows at 1,200# of stuff in the 5er pin would be about 2,160# then the OP has close to 1,000# for stuff!
Road_Phantom
As long as you stay within the manufacturers guidelines, there should be no need to worry. I agree that you're MPG will add up to poop, but it's far cheaper to keep her than to lose thousands trading in for a diesel.
phillyg
I'd do it and I think you'd stay under your limits if you're careful about not overloading the FW and TV.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
Me_Again
Coach-man
Old-Biscuit
rbos57 wrote:
Not to exceed 3148
Which is it........
3280 as in first post OR 3148 :H
Regardless....subtract all people/cargo from whichever number and that is 'available payload' that can 'carry' the pin weight of a 5vr.
Course one needs to look at GVWR, RAWR, Rear Tire MAX Load Ratings also
