Slideout Control Module???
parksplace5454
Hi; I'm brand new to this forum and could really use some help.
I have a 2002 Fleetwood Terry. The main slideout retracts but will not extend. I have contacted Power Gear for troubleshooting info and they need the part number on the slideout control module. I have crawled all over and under this unit and cannot find such a module. Does anyone have an idea where I can find it.
Thanks a million,
Parksplace5454
Pinedale, AZ
9 REPLIES 9
WE_CAMP2
My 97 5th with a powerglide slide had the same type of problem. With a little investigation we found that on the control board a soldered connection on the back side of the board had burnt. Just a little dab of solder and no more problems.
2017 F250 CC SB PSD & 2008 Cameo 5'er
jsikora
I had the same issue on our wilderness by fleetwood. There is no module. The switch is a direct run to the motor. We replaced the switch 2 times. After the second time I did some more checking and found they were running the full current thru the switch (hence melting the switch). I added relays in line, with the battery line feeding the relays. This way the switch only is to turn the relay on. Since adding the relays we have had no issues. I suspect all fleetwoods are the same as I know a friend who had a 2004 with the same issue.
1998 Fleetwood Bounder 30
FORE SALE - 2006 Fleetwood Wilderness 5th Wheel
SOLD - 2010 F-350 PSD Lariet CC 4X4
2000 Jayco Pop Up...The Guest House
Allworth
Not Powergear, but the module for my Accu-Slide is on the basement ceiling. Driver's side, above the battery bin.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
parksplace5454
Yea, I haven't found it yet. I will check out these ideas... thanks a million.
hilke40
My last trailer was a Fleetwood wilderness and the dealer thought it would be under the cabinets but we found it under the shower panel behind the hot water heater. It acted the same as yours, if you need to get it in you can reverse the two wires on motor and the it will then come in but won't go back out until you change module. Module looks like small circuit board. My friends Montana was installed in front compartment with the one for the landing gear. They install them anywhere there is space for them.
parksplace5454
Thanks for the comebacks; the slideout is not hydraulic; it is rack and pinion driven by a gear motor. Have checked the switch but guess I should re-check. Have not thought about looking on the outside wall for the control module... will do.
ScottG
If it works one way and not the other then the first thing I would suspect is the switch itself.
Dennis_M_M
Not a Fleetwood, but for what it's worth the slide out control modules on ours are all side-by-side on the outside wall way back under the bathroom vanity!
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'13 smart CityFlame on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
newman_fulltime
if it is hydrolichave you checked the fluid?
Do you here the pump run when pressing the switch out?
