โJan-07-2018 01:04 PM
โMar-10-2019 04:55 PM
โJan-26-2019 06:18 PM
โJan-17-2019 06:14 AM
RVbikers wrote:
I am sure Prime Time will honor the warranty without issue. They are great and worked with us on our unit. Key to getting stuff done is to be respectful and talk to them the way you would like to be treated. Folks that go in yelling, demanding, threatening get no where. I hope they come back on line, I'd love to upgrade mine in a few years.
โJan-16-2019 08:47 AM
โDec-28-2018 01:12 PM
Nicodemus wrote:
So how do you like your unit now that you've been living in it?
Warranty Items
- Water pump periodically lets water back-flow through it into the freshwater tank (I have tried resetting the internal check-valve by switching back and forth)
- On the Dometic thermostat, Zone 2 always shows the same inside temperature as Zone 1. It originally worked and then back in May, it was showing wildy inaccurate temperatures. A mobile tech did something and now it just always shows the same inside temperature as Zone 1.
- Loose screws holding the wardrobe slide to the camper (Schwintek slide system); they seem to back out when the slide is extended and pull tighter when it's retracted.
- Popping noise in the leveling system (need to add anti-stiction fluid?)
- Washer/dryer is plumbed to rear black tank vs. rear gray tank (have gotten pre-authorization from Prime Time/Spartan for this fix)
- When rear blank tank has overflowed, water leaked into under belly
- When full, the fresh water tank drips into the under belly
- Rear patio awnings makes noise when the extend button is pressed but doesn't extend
- Rear garage door needs to be adjusted on the driver's side (it is looser than the passenger side and driving in a hard rain, we had water come into the camper once)
- Refrigerator seems to put out a lot of condensation and uses an exorbitant amount of propane (a 30lb tank in a week!). Can the doors be inspected for proper seal?
- Refrigerator temperature rarely gets below 50-degrees.
Maybe warranty, maybe not:
- Inspect and adjust brakes, if needed. The brakes seem really "grabby" at times when towing- especially when backing into sites.
Non-warranty Items:
- Repack wheel bearings (by hand, not with EZ lube axles); note: triple axle camper
- Inspect rear exterior steps (Torklift Glowstep Revolution)- I feel like the steps themselves are shifting in the box on the camper
โDec-28-2018 01:00 PM
โJan-20-2018 04:45 AM
โJan-20-2018 03:37 AM
โJan-19-2018 11:51 AM
โJan-15-2018 05:23 AM
ependydad wrote:tinner12002 wrote:
I looked at them online and they appeared to only have 6 lug wheels, 5200 lb or 6000 lb weight rating on the tri-axle models which indicated to me they were already underbuilt in my opinion. Typ of a lot of manufacturers is to just barely use enough to get by.
Do you happen to have a link?
I didnโt crawl underneath but this one is supposed to have 7,000 lbs axles and 8-lug wheels.
โJan-08-2018 02:37 PM
slapshot12 wrote:
Check out General RV, they have several on their website and all are discounted around $25k.
โJan-08-2018 02:24 PM
โJan-08-2018 01:18 PM
slapshot12 wrote:
Be careful on Spartan. We were looking closely at them last year. But while shopping this year, our local dealer said they have stopped production. I'd be concerned about warranty work and parts if the dealer network goes away or factory parts aren't available. Granted, most parts are aftermarket, but it would be something I'd consider. Notice how you only see '17's and they are deeply discounted? Not saying I 100% wouldn't buy one, just be careful. I don't know what the Prime Time future holds. We really liked them, but once we looked at other brands, we chose a different one.
โJan-08-2018 01:14 PM
