Feb-24-2015 12:40 PM
Mar-14-2015 10:53 AM
Mar-10-2015 10:42 PM
CowboyPilot wrote:
Related to the steep driveway situation. I'm fairly confident that we won't scrape going in or out since our bumper pull had no problems. What I am worried about is the flat area of the drive at the top is only about 21' feet long so the truck will still be on the sloped part of the drive (About a 7° slope at most) after the trailer is backed in meaning we'd be trying to hitch/unhitch in that configuration...the actual angle I think would be a little less just based on the position of the hitch relative to the trailer wheels at that point.
1.) Is that even realistic? Can the hitch travel that far up and down?
2.) If I can unhitch it, is there a chance I'll get it unhitched and then be unable to get it hooked back up later?
Out of curiosity, are there any standardish proportions on these things? ie - if I wanted the trailer's front landing gear to stay on the 21' flat surface what would that translate to for total length (how much of the trailer is forward of the landing gear). We haven't bought one yet so we're trying to figure out what size to look for.
Never pulled a 5th Wheel before so trying to hash out the details ahead of time before I bust something. I can't really modify much since I live in base housing. I'm already kind of on the skids with them for installing a 2 leg 30A outlet in the garage since they put the entire garage and outdoor circuit on a single 20A breaker...
Mar-10-2015 04:32 PM
Mar-10-2015 12:49 PM
Mar-10-2015 07:50 AM
Mar-10-2015 07:48 AM
goukcats wrote:
I have a similar drive way & barely clear the rear bumper, pulling into it. I am not sure if it would make a difference backing. I did learn with a previous RV & TV that the trans doesn't do as well in reverse going up hills & it does in drive. That TV would not back that RV up my drive.
Mar-10-2015 07:45 AM
ScottG wrote:
I would just buy a 10' board, place it behind the rear wheel and raise the other end up 28".
Should give you a good idea of if it will hit.
Mar-09-2015 04:09 PM
Mar-09-2015 12:39 PM
Mar-09-2015 12:36 PM
Simple math, isn't it? How far from the back axle to the low point on the back end? How high is the low point on level ground?
Mar-09-2015 10:38 AM
Feb-24-2015 07:55 PM
Feb-24-2015 04:54 PM
Feb-24-2015 04:32 PM
