Tandem axle equilizer and shackle angles
KKELLER14K
I need some input or at least some opinions on this subject and the reason I ask is this: I am replacing the shackles and equalizers on my 5th wheel project with a Dexter EZ-flex and I have the choice to have the shackles either spread out a little like they are now (pic) or go to an equalizer that is just a tad wider which would put the shackles in a more up and down position. Is there any real geometric reason that the shackles are spread out? If they are more up and down does it matter really? Any thoughts or comments?...Thanks for your inputs.
10 REPLIES 10
ACZL
Tho I didn't have a press, neighbor had a vise and worked just the same when "pressing" wet bolt into the tabs. What I did too was mark the end of the bolt w/ a black sharpie inline w/ the holes in bolt so when it got pressed in, the line was at the 3/9 position. Zerks in inside as well. So I have to get under the trailer to grease it. So what. More room. Not sure it it makes that much of a difference, but I jack up the rig to grease so grease goes into the wet bolts easier.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
KKELLER14K
I now know that the wet bolts that are prepressed into the one shackle, as illustrated in the picture of the kit, has been installed at the 3 or 9 o'clock position depending on which way you flip it. Already have the press for the bushings if needed. Obviously you have to make sure the end spring bolts are installed correctly.
http://www.easternmarine.com/dexter-e-z-flex-tandem-equalizer-suspension-kit-k71-652-00
jmtandem
AH HA!...ok so when the spring compresses it gets longer... ok,I get it. That makes total sense.. I got the upgrade idea from Barney..(Thanks again) that is why I stopped right where I did. But I did not still quite understand it but now I do. I'm ordering the EZ- flex which has the wet bolts and bronze bushings. Weather here has been cruddy to..no fun working outside at the moment.. but the upgrade is coming. Thank you all. One small edit...I think I would rather have the zerks facing the inside rather than towards the tires. Just my opinion
What I did was to make sure the zerks work before installing. The instructions suggest either a 3 or 9 o'clock position and some times it can be a little hard to get the grease in after installation. They can be installed either facing inward to the inside of the coach or outward. You will need a drift (or use a bolt with the threads removed) and possibly a handheld press to get the old ones out and get the new ones in.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
azrving
I did an axle flip, 16 inch LT tires, Dexter ez and wet bolts.I put my zerks on the inside because they are easier to get to. My fw sits high so it's easy to get under it and keep an eye on everything and hit the fittings.
KKELLER14K
AH HA!...ok so when the spring compresses it gets longer... ok,I get it. That makes total sense.. I got the upgrade idea from Barney..(Thanks again) that is why I stopped right where I did. But I did not still quite understand it but now I do. I'm ordering the EZ- flex which has the wet bolts and bronze bushings. Weather here has been cruddy to..no fun working outside at the moment.. but the upgrade is coming. Thank you all. One small edit...I think I would rather have the zerks facing the inside rather than towards the tires. Just my opinion.
3oaks
WE-C-USA wrote:
Shackles are meant to be at that angle. Not straight up/down. Install the correct (same length) Ez-Flex & Heavy Duty Shackle/Wet Bolt Kit.
WE-C-USA
Frank & PJ
2022 2500HD GMC Duramax 4X4
2018 Grand Design-Refection 303RLS
BarneyS
I agree with the above posts. Use the size that is the same width as your original equalizer.
If you have not seen it already, take a look at this thread that is stuck at the top of the Travel Trailer forum on the installation of the kit, complete with lots of hints, tips, and pictures.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
jmtandem
As long as you have some of the stuff apart include the wet bolts. Did both the EZ and wet bolts and it makes a difference in towing.
Old-Biscuit
Your spring 'eyes' are wider then the equalizer hence the 'spread' on shackles
Go with the equalizer that is same width as your spring 'eyes'
Shackles then will be more in line with each other for smooth motion
NOW is also a REALLY good time to install 'Wet Bolt' kit so you can grease moving points and have better bushing
