โMay-11-2016 10:11 AM
โMay-11-2016 06:23 PM
โMay-11-2016 06:11 PM
โMay-11-2016 05:58 PM
โMay-11-2016 05:40 PM
WTP-GC wrote:davisenvy wrote:
I have the pinbox up as high as the FW will allow and I'm still towing nose high by 5 inches.
Soooooo.....
If you're 5 inches too high now and you're looking for dead level, then you're screwed. About the best you'll do with a traditional hitch is only going to get you about 3 inches nose high. A modified Andersen will get you close to dead 1-2 inches from dead level, but you're only going to have a little more than 1" clearance which is not enough.
I don't mean to sound harsh, but it sounds like your best bet is to raise the trailer.
โMay-11-2016 03:30 PM
โMay-11-2016 02:24 PM
โMay-11-2016 01:57 PM
โMay-11-2016 01:56 PM
davisenvy wrote:
The dealer just came back with $200 off, so I'm only out $300 additional. I think I'm going to take it. I really like the ease of removal with the Andersen and it sounds like it would suite me best. The DW wouldn't go for the creaking, moaning, and wheezing. I do enough of that without the FW.
โMay-11-2016 01:51 PM
kennethwooster wrote:
I have not used the Anderson but have used around 5 other brands. My favorite is the B&W. By far the easiest to hook too, and no chucking.. Very simple hitch and the easiest hooking and unhooking hitch I've ever used. Sounds like the Anderson is also simple.
โMay-11-2016 01:42 PM
โMay-11-2016 01:39 PM
โMay-11-2016 01:35 PM
โMay-11-2016 01:30 PM
davisenvy wrote:
I'm in a dilemma between an Anderson Ultimate Hitch vs the regular FW hitch. Not trying to start which is better type thing. Has anyone had an Andersen and gone back to a regular hitch? I'm in a situation where the Andersen is too tall for my FW/ truck set up. They can convert the Andersen hitch for the flat bed to fit my truck, but it will cost me another $500 after I trade my current hitch back in. I have never towed with a regular hitch so this is why I'm asking.
Basically is the Andersen towing experience that much better to warrant the up grade, or pocket the $500 and look for a regular FW hitch on Craigs List.
โMay-11-2016 12:45 PM
WTP-GC wrote:
Let me see if I understand the OP correctly:
You currently have an Andersen UH, but you need the lower version. For $500, they offered to "convert" your existing hitch. Or they're offering to give you some trade-in value on your existing hitch.
If that's the case, then here's my take on it. You're going to be hard pressed to find a good used hitch for less than $400 to $500 on CL. You can buy a brand new "decent" hitch for that.
But really, your problem is that you're riding too high in the first place. The Andersen is basically designed to be approx the same height as a traditional 5er hitch. So if you buy another hitch, I expect that you're still going to have the same issue. I own a regular 5er hitch for my other TV, and even at its lowest position, it still sits higher than my lowered Andersen UH
If I understand your situation correctly, you either need to invest in the lower version of the Andersen UH or perform one of the various trailer-lift procedures.
โMay-11-2016 11:56 AM
