After experiencing my LAST freaking Chinese tire failure three weeks ago, I've decided to go with the exact same tire. Your rims will work perfectly. Understand that the G614s are approximately 1" taller overall. So you'll grow about 1/2" between the axle and the top of the tire. Make sure you have enough room between the tires and between the tire and the top of the fender so you don't rub.
When running a 110psi tire, it's very important that you switch over to metal valve stems that can handle that kind of pressure.
Ideally, you'll know the exact weight on each tire and adjust the tire pressure accordingly. Otherwise, you might get a little extra bounce and some excessive tread wear if you run them at max pressure.
Jim
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
