โJan-02-2016 04:38 AM
โJan-03-2016 09:44 AM
Sam Spade wrote:phillyg wrote:
Tire manufacturers compensate for temp changes. Always set pressure in the AM and don't change it until the next morning. They may fail for some reason but it won't be from failing to compensate for ambient temps.
While that is good general advice, one also needs to be aware of unusual conditions.
Some places in the western US it is easily possible to drive in a single day where you might have a temp. span of 70 degrees or more; high in the mountains down to death valley for instance.
Under extreme conditions like that you should check and correct the pressure more often.
โJan-03-2016 09:39 AM
โJan-03-2016 08:47 AM
โJan-03-2016 08:00 AM
โJan-03-2016 07:56 AM
portliz wrote:
Is the pressure stamped on the tire the cold pressure?
โJan-02-2016 04:44 PM
โJan-02-2016 11:43 AM
โJan-02-2016 10:30 AM
โJan-02-2016 09:23 AM
โJan-02-2016 09:20 AM
Coach-man wrote:
People worry about tire pressure with temp's and altitude?
โJan-02-2016 06:49 AM
โJan-02-2016 06:30 AM
โJan-02-2016 06:27 AM
โJan-02-2016 06:26 AM
NHIrish wrote:
You need to check your tire pressures and adjust accordingly as you move from cold temps to hot temps...or the other way around,
