Tire Problems and What to Upgrade To?
Scott_M
Last fall we took a trip to North Carolina, mostly on interstate to visit family. After returning from the 1500 mile trip, I noticed that the rear wheels had come into contact with the plastic fender trim and had also bottomed out in the wells. We travel with empty gray and black water tanks, ยผ full fresh tank. We almost always have less than 1100# of payload (3305 max capacity).
Thinking I had a bad spring, I replaced all springs and shackles with a slightly higher capacity spring and wet bushings. While replacing a tire, I cut my hand of the tire I was trying to mount. I looked at the tire thinking there was a nail or piece of glass stuck in it, but found a small section of steel belt sticking out of the tread. I looked closer and found a bubble in the tread as well. These are the original tires (3 years old and about 6K miles), Power King Tow Max STRโ€™s (ST225/75R15, D Range). I knew that the tires were probably not the best, but I thought I should get at least 10K miles out of them. The GVWR on my fiver is 9950 with tandem 4400 axles and rims 15โ€ x 6โ€ (J).
Anyway, since I now have to replace the tires, I have been looking around the forums and internet. It seems like most people are opting for LT over ST tires. If I type in my tire size I get a lot of hits for the ST size, but very few for the LT size. Having read about a lot of D range tire failures I thought about upgrading to at least E range, but I have to check the rims for the maximum pressure/weight rating. I would hate to have to upgrade the rims as well, but I will if I have to. Anyone have any advice regarding the conversion from ST to LT? I cannot increase my tire size because the axles are already under the springs and I only have about 2โ€ on average of well clearance.
2021 Entegra Odyssey 24B Class C on Ford E-450 Chassis with 7.3L V8
20 REPLIES 20
Me_Again
Here are some 15" LT's. Chris
http://www.maxxis.com/catalog/tire-227-104-bravo-series-ue-168-n
Charlie_D_
Scott M wrote:
I finally figured out where my clearance went. I looked at the spare which had flat tread across the road surface. All four of my tires the center treads are at least 3/8" higher than the outside tread.
I had some tires like that.They had broken belts. Have a tire place spin them for you to see if they are out of round.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
time2roll
I recommend buying tires that cover the full trailer GVWR. LT should be more reliable.
Happy_Prospecto
Just order ST tires, that's what is on the trailer when it comes out the factory door. Besides what could possibly go wrong.
The information is out there, all you have to do is let it in.
Kevin
Retired, Fulltime RV'er, 1999.5 F350 4X4 CC Diesel Flatbed
2007 Alpenlite Defender Toyhauler, 2019 Polaris Ranger
Bob, the Yorkie Terrier helping me prospect til the money runs out
RustyJC
Scott M wrote:
If I can get a year out of the Maxxis tires, I would like to go with LT's in an E Range, but can't find any wheels what seem to be rated for E Range tires. Any suggestions where to look?
Give Scott at Trailer Tires and Wheels a call. If they're available, he can supply them. They're a great company to deal with and can ship premounted and balanced tire/wheel sets with lugs, center caps and everything you need.
Rusty
2014.5 DRV Mobile Suites 38RSSA #6972
2016 Ram 3500 Dually Longhorn Crew Cab Long Bed, 4x4, 385/900 Cummins, Aisin AS69RC, 4.10, 39K+ GCWR, 30K+ trailer tow rating, 14K GVWR
B&W RVK3600
Scott_M
I finally figured out where my clearance went. I looked at the spare which had flat tread across the road surface. All four of my tires the center treads are at least 3/8" higher than the outside tread. As someone mentioned above, their tires did the same thing.
Last week, I ordered one Maxxis M8008 D Range to replace the one with the protruding belt, now ordering three more.
racer4
Upgrade to Load Range E tires. Get Maxxis M8008 ST tires. Check the wheels, buy new if necessary.
Aim for having tire load capacity that is 20% more than the actual tire weight load.
Chris and Pat
2023 Ram 3500 Limited, Cummins, Aisin, dually, Auto Flex Rear Air Ride Suspension
2022 Grand Design Reflection 303RLS
2024 Winnebago Minnie 2327TB
W5CI
Switch to LT tires and dont worry any more about it
2015 RAM 3500 DRW
2004 Cedar Creek 30RLBS
JIMNLIN
op wrote:
Thanks, I checked my rims and that are rated to 2830#. Should there be a pressure rating as well? Looking at the E ratings, am I correct to assume that my rims will not handle the E Range tires at 3420#?
15" wheel rated for 2830 lb capacity means it will handle a ST225/75-15 E at 2830 lb capacity at 80 psi. I've never seen a 15" tire for trailer use that is rated any where close to 3420 lb capacity.
Provider ST tires from Taskmaster are M speed rated and they all come with the nylon overlay on the tread to stiffen the tire which makes a cooler running tire.
I've raised two RV trailers for 16" LT E tires.
The first one I had the OEM spring hangers removed and 3/8"x 4" HRS plates with adjustable holes welded the the main frame rails.
The last trailer was heavier so I had the OEM spring hangers removed a 2" x 3" x 3/16" wall tubing sub frame built up and welded to the bottom of the trailer main frame rails with cross bracing at the hanger area.
Both were done for 16" wheel and LT tire upgrades. I run my 16" LT for 7-8 years and usually the 50k-55k mile range on all of my RV and heavy non RV trailers.
laknox
Dayle1 wrote:
I am also maxed out on the height already. The unit came with under slung axles and clearance (unloaded) is already less than the 3" recommended by Mor-Ryde. I would have to have new shackle and center pivot brackets welded to the frame.
Actually, it is better to add a sub frame than to add longer shackles or longer mounts. The increased length means higher stress on the welds.
If only 1-2" are needed, longer (heavy) mounts might be much simpler. Have seen this several times recently and all but 1 had cross-bracing between the frame rails to stiffen it up.
Another option for a small lift, would be blocks between the axle and springs.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
Dayle1
Larry Day
Texas Baptist Men-Retiree Builders since '01
'13 Silverado 3500HD LT 2wd CCSB SRW, custom RKI bed
'19 Starcraft Telluride 292RLS
Rig Photos
Scott_M
I am towing within 1" of level, probably 1/2 to 3/4" nose high. Odd thing is that when we picked up the unit new from the factory, we adjusted the hitch to tow level and seemed to ride much higher off the ground with plenty of WW clearance.
When we came back from our trip to NC, the nose was riding a bit higher and I seemed to have lost clearance to the top of the well so I dropped the hitch an inch lower.
Also, one side had lost a significant amount of clearance (only about 1 3/8 of clearance from wheel to well) and I thought I had a bad spring. Replaced all four springs and the clearance improved a little bit. Also added bump stops and wet bushings. However the bad tire was on the side with the best clearance. Tanks are empty and the is very little payload on the trailer aside from set up stuff, a couple of bag chairs and some dishes. All totaled less than 500#.
Scott_M
alexleblanc
not sure what your setup looks like but you may be able to raise your unit some and fit some 225/75R16 LT tires, they would be 1" overall diameter taller than your current ones are and they would offer a little over 200lbs more weight capacity so its not a downgrade.
If clearance is an issue now than you'll certainly not be able to run what I suggested without modifications to your unit's suspension.
TV - 2017 F350 CCSB SRW Platinum 6.7 + 5er - 2021 Grand Design Reflection 311 BHS + B&W Companion
On Order - 2022 F350 CCSB SRW Platinum 6.7
