Tire Replacement
Mopar_Mudder
I am contemplating replacing the tires on my 1999 Jayco. Yes they are the original tires and they are in great shape with lots of tread left and no weather cracking at all, it is a shame to through them away. These are not trailer tires, they are Goodyear LT235/85 R16's, I know actual trailer tire quality is really sketchy, but since these are light truck tires I have been letting them run.
Has anyone else ran LT tires for a long period of time? I am going to do some checking to see what it will cost to replace them and decide what I want to do.
2008 Dodge Dually Mega Cab - Resitol Edition
1999 Jayco Designer 3710
28 REPLIES 28
GACamper
Mopar_Mudder wrote:
So are their any problems known with the Goodyear Wrangler HT's . That is what is their now and they lasted 16 years so far, so I am thinking just put the same back on. They are 1/2 the price of a G614 !
If the weight rating of the tire matched the needs for your RV you should be ok. Your RV should have a sticker on it showing you the dry weight & loaded weight. Take the Max weight divide by 4 and that will give some ideal what your tires needs to be rated at. It's better to have more tire then you need then not enough.
2013 Montana 3800RE
RV FlexArmor sprayed RV roof..Big Improvement!
A/C, Color TV and a Microwave...Isn't Nature Great?
04.5 Dodge Ram 3500 Cummins 5.9L
shadows4
I would think if they meet your needed weight requirements for your 5er they would be fine.
2016 4X4 F350,CC,SB,Lariat,6.7L diesel,
2015 Coachmen Chapparal 324 TSRK
B&W Patriot 16K hitch.
Mopar_Mudder
GACamper
We upgrade the tires on our camper. We upgraded to the Goodyear G614 tires at 3750 lb capacity. The G614 is rated 110 PSI at 3750 lbs capacity. You need to check your rims and see what the PSI rating is. Not all rims are rated at 110 psi.
Our camper came with the Goodyear Marathons which are known as "Goodyear China Bombs". Goggle it!
The G614 matched the diameter of the marathons which is a plus and the G614's are made in USA.
Size LT235/85R16
Capacity 3,750 LBS @ 110 PSI
Ply Rating 14
Service Description 126/123 L
Diameter 30.7"
Width 9.5"
Tread Depth 12/32
Stay with a LT tire with a rating the same or higher then what your camper calls for. Stay away from a "ST" rated tires. Also look for the speed rating. If you tow at highway speeds lets say 70 mph or better, you don't want a 65 mph rated tire.
2013 Montana 3800RE
Cummins12V98
Craig's list
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Ready2gonow
I am upgrading my gy 614, grated tires to 17.5 wheels and Sailun H rated tires. The GY have served me well, 15000 miles in 2.5 years I have owned my Mobile Suites. but they were 'born' 4208, and I just had one blow. So, since I have a heavy 5vr, I will bite the safety bullet and get the H tires.....TOO BAD there is no place on the forum to sell my 4 16" aluminum wheels, and 3 decent GY 614s...for $400. Hmmm.
Mile_High
I've always preferred the look of the alloy wheels over the steel now that you ask.
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
FastEagle
Lots of trailers pre 2002 model years came with 16" LT tires. Check your certification label. It might have the answer.
FastEagle
skijlw
I had LT tires on my last trailer. At ten years the tires looked great The first hot day I was traveling about 65 mph when the tire blew. I went to the closest tire store to replace the tires. Another tire was swollen upon inspection. 3K dollars worth of repairs and all was good. I will always get new tires at 8 yr intervals from now on.
Virginia_RVers
After a few blowouts and the damage they caused. I replace my tires every 3 years, no matter how many miles or how they look. Guess it's my piece of mind and well worth the cost to me.
2014 Dodge 3500 DRW, Cummins Diesel
2007 Crossroads Paradise Pointe PF36SK (Rolling Fun II)
Chelsea & Duncan (Traveling Scotty Dogs)
tegu69
I'd just as well have steel. My last trailer had steel all the way around. My current trailer has four aluminum and one steel for a spare??
Mopar_Mudder
tegu69 wrote:
Just curious, did you ever find the date code on those tires. Is it possible that the previous owner may have bought tires and forgot about it and told you they were original.
I looked when I bought the trailer and they are dated 1999.
Any opinions on Steel vrs Aluminum rims?
tegu69
Mopar_Mudder
Got some more info:
Goodyear Wrangler LT 235/85 R16
Load Range E (3042#)
16x6 Rim
6000# axles
GVWR 13,500#
