โMar-09-2016 11:54 AM
โMar-10-2016 06:48 PM
rhagfo wrote:
Part of my point! The tire carcass is the same as on the drivers and trailer, those ribs are likely caps (Retreads), that may have been caped with a traction tread design before! My main point is that the carcass of the tire is the same be it steer, driver, or trailer.
Thanks for the Great Photos.
โMar-10-2016 06:21 PM
Me Again wrote:rhagfo wrote:
ST's likely have a greater profit margin than LT's also.
That said look at semi tires, no special trailer tires. Truckers seldom buy new tires, always for the steer axle, but drivers and trailers usually have caps. Those seem to hold up to the scrubbing of tandem axle both on drivers and trailers.
Russ they do make Rib sytle tread tires for OTR trailers. Tread looks very similar to R250's.
These are Dunlap's.
My R250's parked next to Semi trailer at Circus Circus Feb 2015.
โMar-10-2016 05:01 PM
โMar-10-2016 04:36 PM
โMar-10-2016 04:30 PM
GoPackGo wrote:
Can those two tires be mounted on 80 PSI rims or do you need 110 PSI rims ?
โMar-10-2016 03:32 PM
โMar-10-2016 02:59 PM
โMar-10-2016 02:49 PM
โMar-10-2016 02:41 PM
N-Trouble wrote:
Stopped by America's Tire today and they said no problem they install LT tires all the time on trailers. They were pushing the following as it is what they stock and say they install the most of.
BFG Commercial TA
Cooper Discoverer HTP
Michelin LTX M/S 2
Said they actually do a lot of the Michelin's although I don't know I have heard of anyone on this board running them. Lots of reports with the BFG Commercials though.
I know all three of those are in a different class from the Michelin XPS Rib or Bridgestone Duravis R250 (which is what I was leaning towards) but they said they could order them. Really pushing what they stocked however...
I'm thinking with the weight of my trailer however any of the three they stock should be a lot better than what I am currently running.
โMar-10-2016 01:41 PM
โMar-10-2016 12:39 PM
โMar-10-2016 12:31 PM
โMar-10-2016 12:19 PM
โMar-10-2016 10:25 AM
smkettner wrote:
GY-LT says 3024. Could be a misprint.
GY-ST is 3420. So the LT is rated lower numerically on the sidewall.
http://www.goodyearrvtires.com/tire-selector.aspx
No reason for confusion.
Or are you trying to choose the absolute lowest rated tire for the scale weight of the axle?
Would you go lower rated on your truck based on scale weight?
Good luck with that.
โMar-10-2016 10:09 AM
