Tires again
donewithtruckin
Fifth wheel is 40' #18,000 gross. Ready to invest in 7 new tires. Want to invest in quality. My tire dealer offered 4 brands,all 10 ply. 235/80/16. I am unable to go to bigger size and more ply's because of space. Hercules, goodyear, maxxis, and Samson. I know about good rating on maxxis, should I go with them?
17 REPLIES 17
All_I_could_aff
I also used trailer tires and wheels.com and was 100percent satisfied with the product and the service
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollinโ€™ on 33โ€™s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
BobKrogstie
donewithtrucking wrote:
THanks for all the free advice. Trouble is the tire guy says he cannot get sailum st's. Has anyone heard of trailertiresandwheels online?
I just bought 4 HD aluminum wheels with Sailun S637 ST235/80R16, SS lug nuts, SS EZ-lube center cap, mounted, balanced, metal valve stem, and shipped online today for $317 each from trailertiresandwheels.com.
Bob and Natalie
2008 Grand Junction 37QSB
2009 Dodge 3500DRW Big Horn 4X2/CC/LB/CTD/4:10/Auto
donewithtruckin
buc1980
Go with Sailun they good tire and affordable.Goodyear are very expensive
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.RV flex roof 2023
fj12ryder
tinner12002 wrote:
donn0128 wrote:
fj12ryder wrote:
Well, 28,800 lbs. carrying capacity for an 18,000 lb. 5th wheel, which should have around 15,000 lbs. on the axles, might be a bit of overkill. ๐Ÿ™‚ Heck, you probably wouldn't even have to put any air in them. ๐Ÿ™‚
Where pray tell do you come up with 28,800 pounds carrying capacity?
4800 times four equals around 19,000 pounds.
Well OP was talking about purchasing 7 new tires so we are assuming that he has a tri-axle RV and was getting a spare also.
Yup, what he said.
Howard and Peggy
"Don't Panic"
JIMNLIN
No need for 17.5" tires and wheels on a tri axle trailer with 6k-7k axles.
I frequent several commercial haulers forums. The all steel ply carcass commercial grade Sailun S637 in a ST235/80-16 G at 4080 lbs are very popular with trailer owners and heavy loaded 6k and 7k axles. These type ST tires have nothing in common with the ST E tires other than being black and round.
Also the Hercules H-901 get a lot of good comments.
The Goodyear all steel carcass G614 in a LT235/85-16 E at 3750 lbs capacity are very popular with rv folks but are pricey.
I see Provider ST tires come OEM on several brands of heavy equipment trailers/6k-7k axles. There a new gen M speed rated and come in a ST235/80-16 E at 3520 lbs or a ST235/85-16 G at 4080 lbs capacity
Maxxis ST8008 ??
Maxxis gets a lot of hype on RV websites but not so much on working websites. With over 30 members from rv websites reporting issues with them....they have been the better of the ST E type tires on smaller trailers.
tinner12002
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
hbillsmith
Sailuns can run just fine at 80psi. I checked with Sailun and the agreed and sent me their current load inflation chart. At 80psi they are an E load rated tire. Also all 17.5in tires require an 8 lug wheel. Their are no options for 17.5 on a 6 lug wheel.
Wildcat2016-295rsx GMC2015-2500HD-DblCab D'max/Allisn+4x4 6.6'Bed
Maxxis235/80/16E;Andersen Ultimate2+4"offset;Airlft1 WirelessComp;GroundCtrl3;MorRyde RubbPinBox+CRE3000;3-Slidecovrs;Champion3100w/DIY ExtndRun;10'Portabote+5hp;Furrion48cam
Visited States
donn0128
fj12ryder
Howard and Peggy
"Don't Panic"
donn0128
How about 4805 pound load rating each!
Overkill? Maybe, but look on the plus side, easy to find, good for a 100K miles, and probably cheaper than some 16 inch options.
fj12ryder
donn0128 wrote:
Aw geeze, just go online and buy 17.5 inch tire and wheel package and be done with it. With ratings well over 4000 pounds each you will never regret it.
Yep, that describes the Sailun alright: 4080 lbs. carrying capacity. Oh yeah, you won't need new wheels either since they come in the 235/80/16. ๐Ÿ™‚ So you can save yourself some dough. Win, win, win. ๐Ÿ™‚
Howard and Peggy
"Don't Panic"
md_procouple
We'll stck with our Sailuns, have had great results on the 3rd year with them. Good Luck and Happy Camping !!
Vickie, Me, and "Scruffy" our dog make THREE
:W
Pioneer32
Just bought a set of Goodyear Endurance ST225/75R15s. They are the only ST 15" tires I have found that are made in the USA. You might want to check them out.
