โNov-10-2013 06:34 PM
โNov-12-2013 03:00 PM
Bumpyroad wrote:snowdance wrote:
w Blowing the water heater out will not really work as you leave a lot of water in it. Helped a freind replace his this spring because he blew it out instead of draining it.
it sounds like your friend didn't even drain his system including water heater before he blew it out. bad move.
bumpy
โNov-12-2013 02:03 PM
โNov-12-2013 01:47 PM
โNov-12-2013 11:25 AM
Bumpyroad wrote:NC Hauler wrote:
I'm a firm believe in, "Better safe than sorry" as another poster stated....I have a 39' 5er with 4 slides....I drain the 10 gallon water heater, put it in by-pass and blow the lines out, then I put the RV antifreeze in all traps....takes all of 10 minutes to do what I it..
out of curiosity, why do you bother messing with the wh bypass if you aren't using antifreeze? not enough volume out of the air compressor?
bumpy
โNov-12-2013 09:24 AM
โNov-12-2013 08:24 AM
robdnorm wrote:
I just recently purchased a 2012 Flagstaff fifth wheel that has the enclosed under belly and heated tanks. It also has a heat vent in the storage under the neck. We just took it out for our first trip this past weekend and plan to go again during Thanksgiving. The weather is calling for a low of 20 this week for two nights. I was wondering if I left the furnace running the two nights if it would keep the lines safe. It also has an outside shower on it. The last camper I had was a Jayco and it did I not have all these features. I would have winterized it without a doubt. I was just wondering if any could shed some light on their past experiences..
โNov-12-2013 06:34 AM
โNov-12-2013 03:45 AM
robdnorm wrote:
Thanks for the replies. I should have been more clear in my original post. I plan to winterize the unit after our trip in two weeks. We are experiencing an "artic blast" for two days here in TN. We typically do not experience this type weather until January/February. I have already winterized my horse trailer LQ for the year. Ultimately I would only be looking at the temps for two nights. After that they are calling for the temps to jump back up to the 60s. I was just questioning if the all the extra heaters and insulation would keep me protected those two nights.
โNov-12-2013 03:37 AM
โNov-11-2013 08:50 PM
โNov-11-2013 09:23 AM
โNov-11-2013 05:53 AM
โNov-11-2013 05:42 AM
โNov-11-2013 05:37 AM
