Jan-29-2016 07:47 AM
Jan-29-2016 01:42 PM
goducks10 wrote:Bobandshawn wrote:
One issue, which I consider a big issue, with the Ram trucks is the only gear ratio available unless you get the DRW option is 3.42. I know that diesel is a torque monster, but 3.42?
I really wanted a Mega Cab DRW rig but the price and difficulties living with it when I don't tow that much just wasn't in the cards. I ended up with a 2500 Mega Cab short bed with the 6.4 Hemi and 4.10 gears. $45K sticker ($10K off) and fully loaded. I have the air suspension which I probably would of never ordered, but now that I have it I really like it. I still just have a pull trailer with a hitch weight of about 850 lbs. Drop the hitch on the ball and the truck makes some RD D2 noises and boom-it raises right back up. My payload on the 6.4 is about 2900 lbs and tow weight is 15.5K lbs so I'll be looking at a 12-12.5 max weight rig with a dry hitch weight of 1700-1800 lbs.
The difference is the TQ of the Cummins. Most reviews of guys towing upwards of 8-9000lbs with the 6.4 and even 4.10 gears complain about the 1-2 spacing when in certain situations. It won't shift up to 3rd and if it does it bogs when under certain speeds. Never hear that with guys towing 9,10,11,12,000lbs or more and 3.42s with the Cummins. Same tranny too.
As to the OP get the DRW if you're pushing 3000lb on the pin. That doesn't leave much left for passengers or other gear in the truck. If you can handle the up cost of the DRW and the driving then get the DRW. Never heard anyone complain when towing with a DRW.
Jan-29-2016 01:23 PM
Jan-29-2016 12:47 PM
Jan-29-2016 12:24 PM
Bobandshawn wrote:rhagfo wrote:
Ho you gassers that don't understand the power of TORQUE! :S
Should have got the diesel with 3.42's :B
That said, you got a very good engine and gear ratio, and it will server you, very well.
To the OP's question: I would consider the break point around 15K, although if I were to replace our 2500, likely get a 3500 DRW.
In the 2500 flavor the 6.4 has about 1000 lbs more cargo capacity than the 3.42 geared CTD and the tow capacity of the Hemi is a nominal 50 lbs higher. That 1,900 cargo capacity wasn't cutting it for me on the CTD. I didn't want a 3500 and couldn't justify the $6,000 extra cost for a CTD and I certainly didn't find a CTD $10K off sticker so I'd of paid at least $15K more! I get worse mileage, but once you figure the added cost of diesel and that stupid DEF stuff I'd have to drive a lot of miles to make ends meet. My current mileage is averaging about 11.5 city and 17-18 highway. Towing my 8,500 lb trailer I am pushing it to get 10 mpg. Of course the power is such I am towing faster. And I love that Hemi sound.
Jan-29-2016 11:19 AM
Jan-29-2016 10:35 AM
Porsche or Country Coach!
Jan-29-2016 10:08 AM
Halmfamily wrote:
I've towed my fifth wheel at 14600 lbs with both a SRW 3500 and now a DRW 3500. The DRW feels much more stable with no side to side wiggle I had in the SRW. As for weight I think it's a matter of what you're comfortable with and within your trucks specs. As for me I'll always have a DRW.
Jan-29-2016 09:33 AM
Jan-29-2016 09:15 AM
Jan-29-2016 09:08 AM
Jan-29-2016 08:52 AM
jmtandem wrote:At what weight would you consider a DRW to be mandatory whilst towing a fifth wheel ?
Mandatory? Not sure. But at around 16,000 pounds I would want a dually. At around 12-13,000 the diesel. At 16,000 pounds pin weight will be at or around 3200 pounds, plus the hitch, plus all the people and stuff in the truck. You will likely be close to payload gross on a SRW.
Jan-29-2016 08:50 AM
Jan-29-2016 08:41 AM
